Old 10-24-2004, 12:36 PM   #1
1972ChevyCheyenne
Cab Differences
On a previous post with pictures someone noted the cab was not even the right for the year. I think it was a 70 cab on a 72 model. Since my cab was rusted enough on my 72 I got another cab off a 70. The only difference I could see was the 72 has Vents or Pressure Relief Devices in the door pillars, while the 70 did not. Can anyone enlighten me on the differences? Currently I have a rolling chassis and soon going to be getting the cab together again, so I was wondering if I am going to have problem taking 72 parts and putting them in the 70 cab. Thanks in Advance
Jamie
1972ChevyCheyenne is offline   Reply With Quote
Old 10-24-2004, 12:43 PM   #2
Gee_Emm
You will have to convert the gas pedal linkage, 71 72 used cable 67-70 used the rod. It will be a little bit of work if you want it to look stock.
Gee_Emm is offline   Reply With Quote
Old 10-24-2004, 12:46 PM   #3
tom hand
CCRider
tom hand's Avatar
Rearview mirror mounts to cab 71 down....in 72 they started glueing them to the windshield
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 10-24-2004, 06:59 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That was me that noticed the 69/70 cab on the 72. It was the gas pedal. On the 71/72, (cable operated throttle) the pedal is suspended from the top, not touching the floor. I noticed that pic showed the pedal mounted to the floor. And since it didn't have the 67/68 hand operated parking brake, I knew it was a 69/70 cab.
There are differences in the heater box somewhere in the line up, plastic to metal, but I am unsure of the specifics.
71 was the only year to have a raised punting pad on the sheet metal just over the windshield for the rear view mirror.
Old 10-25-2004, 12:29 PM   #5
KY Wildcat Phan
Smile
I am wanting to put a 71 GMC cab on my 69 swb chevy is this going to be a problem? Can I just use the cable linkage that is in the 71 or will i have to switch to the rod?
thanks
gary
KY Wildcat Phan is offline   Reply With Quote
Old 10-25-2004, 03:45 PM   #6
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
you should be able to stay with the cable
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 10-25-2004, 06:10 PM   #7
billsbowtie
billsbowtie's Avatar
i have a ? is 1 ton cabs the same as 1/2 ton cabs they look the same to me
billsbowtie is offline   Reply With Quote
Old 10-25-2004, 09:46 PM   #8
Longhorn Man
yup..one ton cabs are a dead on match.
Old 10-25-2004, 11:29 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's my belief that all one tons had cab lights on the roof.
If so, definitely different. The cab lights set on raised pads stamped into the roof skin.
Old 10-25-2004, 11:34 PM   #10
Longhorn Man
Nope, not true.
The one ton with 9 foot step, and one tons with the 8 1/2 foot fleet did not require clearance lights.
Old 10-25-2004, 11:36 PM   #11
Tx Firefighter
So all cab/ chassis had the lights, but no other trucks did then?
Old 10-26-2004, 05:44 AM   #12
Longhorn Man
it was optional on all 10 - 30 trucks.
i do think it was a required option on all cab/chassis...bit I'd have to look to be 100% sure.
Old 10-26-2004, 07:56 AM   #13
68C15
blood type; Retumbo
68C15's Avatar
lets all turn & face the Columbus Ohio area at noon & bow to Andy. he is the high priest when it comes to these trucks. (we highly appreciate your wisdom)
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 10-26-2004, 06:12 PM   #14
Longhorn Man
There's ppl on here that know more than I do...trust me, they prove me wrong all the time.
