Old 10-24-2004, 08:39 PM   #1
newsalem2004
Question 1988 Chevy 4X4 pickup question
I have a '88 k1500 and the front diff will not engage.
There is no power going to the actuator and I was wondering if there is a switch on the transfer case or somewhere else that is activated when shifted into 4X4 to then activate the acuator on the differential.
I checked the fuse as I beleive that the acutator is on the same fuse as the heater/ac in the fuse box.
I am completely confused on what it could be.
Help please!!!!!!!
newsalem2004 is offline   Reply With Quote
Old 10-24-2004, 10:13 PM   #2
ChevyTech
The switch that supplies power to the front axle actuator screws into the transfer case above where the shift linkage connects to the transfer case.
I think you are correct that the heater/ac fuse is the fuse that suplies power for that circuit.
Also check ground side of the actuator circuit.
ChevyTech
Old 10-25-2004, 10:27 AM   #3
STEVE A WILBURN
My Actuator Went Out My Heater Didnt Work. They Or Not Hard To Put In. Steve
JUST HAPPY TO BE ALIVE.
STEVE A WILBURN is offline   Reply With Quote
