Old 10-24-2004, 08:40 PM   #1
newsalem2004
Question '88 4X4 question
I have a '88 k1500 and the front diff will not engage.
There is no power going to the actuator and I was wondering if there is a switch on the transfer case or somewhere else that is activated when shifted into 4X4 to then activate the acuator on the differential.
I checked the fuse as I beleive that the acutator is on the same fuse as the heater/ac in the fuse box.
I am completely confused on what it could be.
Help please!!!!!!!
newsalem2004 is offline   Reply With Quote
Old 11-01-2004, 10:34 PM   #2
V8trucks
I had the same problem with my 88 K2500. I wired a switch from a 12v source, ran it down to the actuator and then ran a new ground. Shift into 4wd then flip the switch. It's easier than trying to trace all the factory wiring...
Dave
V8trucks is offline   Reply With Quote
