Professional Grade
Seperating two peice driveshaft
How does a guy go about seperating the front and rear part of a two peice driveshaft behind the steady bearing? I need to know so I can get my u-joint fixed.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
#2 | |
DAMN, I love Big Blocks!
Russell, there's usually a screw-on sealing cap on the end of the forward shaft. It will unscrew, just like a nut. If it's stubborn, use large slip-joint pliers....carefully. Then the rear shaft should come off.
Marc Bona Hobbs, New Mexico 1976 1/2 ton GMC High Sierra. 454 c.i.d./ TH400. *Soon to get a mild warming over.* 3.40 rear. ![]() |
