Steering Arm Removal
Need help, I am installing my lift kit. I need to install a drop steering arm, but cannot figure out best way to remove old one. Is there a procedure I am not aware of that makes getting the arm off and the wedges out without "cutting" everything off? Thanks, Joe Bob.
Premium Level Member
Make sure your only hitting down edge/ends of it . The cones will start to rise just a bit. Use a screwdriver and tap at them to turn them out.
its all about the +6 inches
Could go to Auto Zone and rent a pitman arm remover. It'll get that sucker off in 30 seconds.
Andy, tell me more!
Geared for Collision
i had a time till i finally took some where and the guy bangs few times on side where shown in pic below and cone washers fly out real ez, made me feel like an idiot. luckily he said it was free for that
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
Thanks for the picture Bud! I was hitting up and down, but not at that location. I will give that a try next!
I failed to notice you were talkin 4X4 stuff...I don't know jack about the 4X4s...so disregard my post.
steering arm
Get it agianst somthing hard and use a bfh smash it on the sides . I am from NY also you should know how to use a torch
Believe me, the torch was my first choice! However, the guy who's garage I am working in right now is in the middle of finishing up another truck, and did not want any "torching" going on until that truck is out of there. His garage, his rules! I am just extremely thankful he is letting us use it to get the mechanical work done. Once we are done, he is going to begin on the body work with me as an assistant.
user # 2756
![]() Join Date: Jun 2001
I had to heat mine and then hit it where budweis shows in his pic.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
