![]() Join Date: Mar 2004
wanted: aluminum vortech heads
hey,
i'm looking for a set of aluminum vortech heads for a sb 350. would someone have a rebuildable set i could purchase? thanks, ondrew p.s. zip is 60190 for shipping reasons |
They never came on anything! They are called fastburn heads and they are pretty expensive! I doubt you will find them used!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
they came on 92-96 vettes and 93-97 camaros and firebirds, search ebay. you can usually find a pair for 500 bucks
#4 | |
I don`t think those were Vortecs. Those are off of LT1 reverse cooled motors. I don`t have any experience with those heads or how/if they work on earlier motors.
Anthony |
91 SWB 383
i have a set of Vortecs . they came off a 96 motor . heres the casting 10239906.. u can go to www.motech.com and cheack what i'm saying. i'll let them go for 300.00 +shipping .. went with another set of heads and don't need them any more .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040, http://photobucket.com/albums/q169/k...ahoe prostreet |
#6 | |
![]() Join Date: Nov 2003
Was that a bad link? No info there. |
#7 | |
Thanks Scot
91 SWB 383
i was told abvout 3000 u know how that goes . i always rebuild . let me know scoti . i will be in dallas this weeken. to meet with 5-8 to get his hood .
here the link . i did it wrong . http://www.mortec.com/
go ahead and let them go to scoti. i have found a set localy.
thanks guys, ondrew |
906
10239906 or '906 heads are iron, not aluminum.
also they don't flow (the 906 head) as goood as the "L31 heads " whos part # is 12558060. The Aluminum heads are either the L98 head part #12556463 which has a 58cc chamber w/ 170cc intake port They came on 87-91 corvette w/TPI.And then theirs the BIG dollar ones the fast burn head part #12464298 their chamber size is 62cc w/210cc intake port
#12 | |
I believe that is a mis statement. At one time chevy hi perfromance stated that..but then recanted in the following issue.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
