i love summertime
removing the sticky crap under the pinstripes?
sorry for another question guys, ive been flooding the board lately but what i want to know is right now im removing the awful blue pinstriping on my 71, i did the tailgate tonight just to test the grounds, i used a heat gun and that got the stripes off no problem but in spots there is still the adhesive. is there a cleaner that will remove this sticky stuff without harming paint?
thanks in advance, Derek
1967 shortbox stepside Chevy, 365 hp 327, th400. GLOVE BOX LIGHTS FORSALE, click link for info http://67-72chevytrucks.com/vboard/s...d.php?t=273724 |
Member since 2000
Goo-gone. It's some piss color looking stuff. It's extract from oranges. We took some bumper sticker off a buddys car and used the goo-gone to take off what glue was left from the stickers. Worked like a charm with some eldbow grease.
Geared for Collision
ive used wd-40 sparingly many times and it works.
MEMBER OF THE 4 WHEEL DISK BRAKE CLUB 1970 C/K20 3/4 Ton 1996 Collectors Edition Corvette 1977 Corvette Coupe |
Got Light Emitting Diode?
might have a color difference from where its not faded
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
go to a paint supply store and buy (acryliclean) not sure on spelling but it will remove the glue without removing the paint.
2004 Extended cab LS silverado ![]() 2001 Buick Lesabre 1968 Chevy Custom 10 LWB Anniversery model 2008 crew cab lt (rolling on dubs) "The nice part about living in a small town is when you don't know what you're doing, someone else always does" |
wd40
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
i love summertime
wd40 wont hurt the paint? doesnt cause it to fade or look dull? the paint allready is kinda shi tty but i dont really want to make it worse
thanks for the ideas guys
bbq lighter fluid
Truck #1: 1972 Chevrolet K20 Cheyenne Custom Camper SB400, TH400, NP205 Truck #2 1967 Chevrolet C10 Custom Sport Truck 327 small journal, TH400 |
wd40 won't hurt anything I use it for bug and tar remover
i love summertime
cool, thanks for all these ideas, ill have to give them a try tonight
wd40 has never hurt paint on any of them ive used it on. i guess if paint is real chalky it could change the color a bit not sure. after your done you could buff it out to help blend it.
The Blazer King
3M adhesive remover is what i use.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
#13 |
i used goo gone to take off everything from bumber stickers to emblems! good stuff! helps to heat it a little too.
no longer have a ride, but still a fan! |
#14 |
Thanks for the tips. I have some inspection/registration stickers that left glue on the windows.
Hook'em |
#15 |
Keepin an eye out
I used a product called "Sticker Shock" that worked, from Pep Boys after trying just about everything else and I mean everything else.
This was for the big stickers that came on my Toyota.
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
#16 |
i love summertime
hey guys, just got inside from removing some of the prinstriping, 2 hours later ive got the bottom stripe on passenger side done, so i guess about 6 hours to go, do a bit everyday after work, next weekend it should look a lot better, thanks for the ideas guys, i used brake cleaner it worked like a hot damn but then i ran out so i used wd40 and it had the same results just took a bit longer
#17 |
Howzit?!?
It sounds like you are further along than considering this, but one of those air pinstripe eraser tools work great!
I got this one ![]() Good Luck.
Jason Hawaiian-J 70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters. 1999 Chevy Tahoe 2004 Mini Cooper S 71 BMW 2002 - Sold |
#18 |
i love summertime
jason-thanks for the heads up, i concidered those wheels but this paint is getting old and id hate to see the paint get ruined, ill keep poking away, ill get it done, kind of fun having something to do on the truck , i missed it when my dad and i finished my 67 i had nothing to tinker with
#19 | |
Howzit?!?
I know what you mean, one small set of stripes can be fun. I got the tool cuz this van had 27 pinstripes (with three different sizes) on each side, all the way from front to back... the back had them and the front hood had six more. I "NEEDED" that tool ![]()
#20 |
you would still be there with a heat gun and goo-be-gone
#21 | |
Howzit?!?
#22 |
"AIRBORNE"
If any of you do any painting. WD-40 is terrible on paint jobs. Silicone and paint don't mix. Fish eyes!!!! If you have anything in the garage you plan on painting and it has had wd-40 on it. To include bare metal. Use mineral spirits or thinner to wash it down. If you are preping a truck for paint you should put any brand dish washing soap in your wet sanding water. It will cut and remove any waxes or silicone (wd-40,armor-all, Ect....) that have been used on the surface. Most body shops will have no wd-40 anywhere near the prep area of the garage.
69 GMC 2500 4X4 long stepside 454 BB |
#23 |
I don't get the hint that banned means banned
70chevylongbed got it, use a GUM WHEEL, that's what i used to mine! make sure you dont burn through your paint like i did though!!!
#24 |
2A674 Tank Rat
I've used Fingernail Polish remover before even on plastic stuff. I even have used it on the windshields of plastic models too.
'92 GMC Sierra, Sportside, 2wd, 350, Black '92 Chevy Silverado Extended Cab 4 x 4, Blue USAFR = 2A674 = Aircraft Fuel Systems Maintenance i.e. Tank Rat |
