"GO DAWGS"
F/S 73 Tach cluster
73 Tach cluster 100.00 shipped.
Did you sell and ship that cluster yet ? If not it looks like the one i need .Is the oil pressure mechanical ?
If it is the same as a 78 Blazer, I might be interested...
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
Professional Grade
To those interested, keep in mind that this is a cluster with an AMP gauge rather than Volts, and has a mechanical oil pressure gauge rather than electric.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
"GO DAWGS"
It is now on ebay, I waited about a week and got no response so I put it on ebay. I do not have the item # on hnad but you can find it under seller Dawgfan227. You may be able to snag it cheaper.
Thanks PT
70 CST SWB 70 NOVA 93 Indy 500 Pace Truck (SOLD) 94 SILVERADO SWB 5/7 drop 2000 Silverado swb 2005 Nissan Altima 3.5 (Surprisingly very fast) 2004 GMC Yukon XL Denali BATESBURG, SC. 29006 29006 Some of my restorations http://www.snapfish.com/snapfish/thu...NAME=snapfish/ Restored Tach tins 8 cyl - 6 cyl http://67-72chevytrucks.com/vboard/s...d.php?t=518185 Contact info(Not my paypal address) DAWGSFAN227@YAHOO.COM God Bless Our Troops |
Does anyone know for sure if this would just be a plug-n-play switch w/the factory guage set-up? I'm curious about the fuel level gauge being in the different location. Any wiring harness differences? Does the factory 74 harness in my truck have the correct wiring (circuit board) for a tach?
What do we get for $10?
SCOTI
If I was a bettin' man I'd say you could "plug and play". I was able to on my '77. The tach harness is seperate from the circuit board. You've got 3 prongs on the back of the tach, ground, 12 volt, and one goes to your coil. (They're all marked) It's nice to have a factory tach harness, but you can do it yourself pretty easy. BTW, I get more comments on the tach than anything else on the truck, so I'd bet you'd be happy with one too! Good Luck! Joe
1977 GMC K25 400/400/205 1989 Chevy Suburban R1500 350/700R4 (work beater) 1994 Chevy K3500 dually 454/4L80 1996 Corvette LT4 350/ZF 6 speed 2000 Bonneville SSEI Supercharged 3.8 Liter V6 1966 Chevelle 2 door sedan (Needs major repair )
#8 | |
| Bookmarks |
