Old 10-25-2004, 06:57 PM   #1
SERE
"AIRBORNE"
SERE's Avatar
67-72 factory tach adjustment
I posted a question on engine & drivetrain. Does anyone know how to adjust a 67-72 factory tach? I have got one that has a 3200 limiter of some sort on it. It just stops a 3200 RPM. The pictures are the dial on the back and I can't find anything in the manuals. Please help.
69 GMC 2500 4X4 long stepside 454 BB
SERE is offline   Reply With Quote
Old 10-25-2004, 07:28 PM   #2
JimKshortstep4x4
Smile
The adjustment on the back is for calibrating the RPM's against a known reference. I don't believe that it will help your problem. I suspect that you have a sticking needle problem. It is possibly rubbing against the face or part of the mechanism.
Jim
Old 10-25-2004, 09:37 PM   #3
SERE
"AIRBORNE"
SERE's Avatar
Thanks, What are the increments on the dial? Clicks or turns = ???RPM
If you know. I can always go trial by error.
Thanks again, Steve
Old 10-26-2004, 08:36 AM   #4
Rod
I think its just getting stuck also.....I have ahad a few that do that....usually just a bit of taking apart and cleaning, it should work.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 10-26-2004, 07:58 PM   #5
ckhd
ckhd's Avatar
If I remember right, there are no 'increments'. I hooked up a Sun tach up with the factory and had to fiddle with the adjustment for about 10 minutes before it read the same as the Sun. I would adjust it at, oh, 3000 rpm, then when I dropped it back to idle, it wouldn't match & vice versa. I don't know if it was dirty contact points in the adjuster or what, but it finally lined out and is very accurate.
my 2¢ - t.i.o.l.i.
Bowen
1968 K20 fleet
1969 K10 swb fleet
1972 K10 Suburban
1972 C10 lwb step
1992 K1500 'burb
1995 K2500 'burb
1997 C1500 'burb
1999 K1500
2000 K1500 'burb
Why do I own so many Suburbans?
ckhd is offline   Reply With Quote
Old 10-26-2004, 10:42 PM   #6
SERE
"AIRBORNE"
SERE's Avatar
Thanks, I wil let you know how it works out.
