Old 10-25-2004, 11:06 PM   #1
67ChevyC10Stepside
67ChevyC10Stepside's Avatar
how to install?
i bought 67-72 cab mounts from mothertruckers and they dont have any instructions with them....there are 2 rubbers with steel washers like bonded to them.....two almost identical that are all rubber.....2 cones with a little chunk out of each one......and 2 cones that curve in in the center then back out at the top and bottom....then there are 4 bolts 4 nuts and i think 2 big washers 2 smaller washers....and i think that's it.....(doing this from memory)
67 c-10, 400 SB, TH350, 4.10 gears, Blazer tank,camaro tach, sidemarker fuel fill (soon)
WTB: stepside parts, 67 front end parts, 67 small window cab. posi for 3.73 or 4.10 for 12 bolt and 10 bolt.
67ChevyC10Stepside is offline   Reply With Quote
Old 10-26-2004, 07:05 PM   #2
67ChevyC10Stepside
ttt
Old 10-26-2004, 07:07 PM   #3
724wdcopper
graphic designer
724wdcopper's Avatar
do you have an LMC catalog? good for exploded views, but that's about it!
724wdcopper is offline   Reply With Quote
Old 10-26-2004, 08:36 PM   #4
67ChevyC10Stepside
hmm....i dont have the square pieces as shown for the front ones...and i dont have number 14 and 20....they are made into the bushings.....now the only thing left to figure out is....is 15 or 21 the steel ones?
Old 10-26-2004, 08:37 PM   #5
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
67ChevyC10Stepside check your PM box
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
