BlahBlahBlah
no heat/defrost fan
before i dig into this is it more likely the switch or the motor?...72 burb, thanks
Got Light Emitting Diode?
fuse good??? pull the wire that connects to the fan and see if you have power
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
67-72 Addict!
Start with the fuse as already stated. 2 weeks ago I noticed a broken fuse and replaced it but the fuse next to it was also broken. I was in a rush to get my dads heater working and before you know it I was chasing my tail not realizing/seeing the other broken fuse as it was getting dark outside.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
