Old 10-26-2004, 04:28 AM   #1
jesse977
jesse977's Avatar
Taillights wont light up..Help!
Both of my rear taillights wont light up. I checked the bulbs,flashers, and fuses and they are fine. When I put my hazard lights they will flash. I dont know whats wrong. I switched the bed on my truck, I have a 74 GMC and put on a 78-79 bed. Any help or advice would be appreciated, Thanks.
jesse977 is offline   Reply With Quote
Old 10-26-2004, 09:24 AM   #2
Russell
Professional Grade
Russell's Avatar
Check your brake switch, mine did that to me outta the blue last night, just pulled the switch out and put it back in, then it worked, lol
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 10-26-2004, 09:49 AM   #3
mhicks
mhicks's Avatar
Check the plug under the bed near the back bumper.
mhicks is offline   Reply With Quote
Old 10-26-2004, 09:22 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
There may be a ground issue at this time. Put a jumper wire on the body of one of your lights and then connect it to the frame, this could be a common thing in the back of the truck and the ground circuit is feeding back through of of the other circuits. The suggestion for checking the plug is an excellent one. This plug is a little different than some of the other trucks and it may need to be seated better to get a good connection.
piecesparts is offline   Reply With Quote
Old 10-27-2004, 04:15 AM   #5
jesse977
jesse977's Avatar
Brake switch??? Where is it??
Old 10-27-2004, 12:39 PM   #6
bigblock73
yeller
bigblock73's Avatar
Under the dash...your brake pedal arm pushes against it. When the switch is not in contact with the pedal, your brake lights should turn on...when they make contact, they should go out.
bigblock73 is offline   Reply With Quote
Old 10-28-2004, 02:38 AM   #7
jesse977
jesse977's Avatar
Thanks, Im gonna check it.
