Old 10-26-2004, 02:14 PM   #1
skokie
skokie's Avatar
Need Fan Size
What is the size of the steel 5 or 6 blade fans with a fan clutch? 17 or 18 inch?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-26-2004, 03:25 PM   #2
stickshift_or_walk
Left Foot Functioning
stickshift_or_walk's Avatar
Skokie,
For my new GM shroud (for a C10 SB V8 with A/C), the opening is just over 19". I talked to the folks at Flex-a-Lite recently, who advised that the fan should be approximately 1" less in diameter than the shroud opening, and they suggested their 18" (#5718 standard rotation, #5918 reverse rotation) for my application.
They also recommended their #5657 HD Thermal Fan Clutch for my reverse rotation application (serpentine pulleys). Not sure if that also works for standard rotation, but it looks like it does.
Here are their web pages for fans and clutches.
I ordered the parts from Summit Racing.
SSOW
69 C10 (#1 son's ride)
72 C20 (Dad's farm truck)
82 K30 (Ex - brush pumper project)
stickshift_or_walk is offline   Reply With Quote
Old 10-26-2004, 04:07 PM   #3
skokie
skokie's Avatar
I checked summit and its looking like its going to be the FLX-5718 for the fan and FLX-5534 for the fan clutch. Not sure about the fan clutch though since there are 4-5 to choose from.
68 build thread
Old 10-26-2004, 04:44 PM   #4
stickshift_or_walk
I went with the HD 5600 series clutch based on recommendations from my vendors, since I'll be running A/C (Old Air system).
The 5500 series does not have the bi-metal spring to react better to temp changes as discussed in the other thread. If you're not seeing heavy loads or high heat, you'll probably be fine without the HD.
SSOW
Old 10-26-2004, 05:20 PM   #5
skokie
skokie's Avatar
SSOW
That and I am not running a ac. Thanks again ..
68 build thread
Old 11-08-2004, 04:28 PM   #6
70short
Thumbs up Fan
Hey SKOKIE
Did you get your clutch fan set up yet???
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 11-08-2004, 05:11 PM   #7
skokie
skokie's Avatar
I got the part numbers from summit. Looks like its going to end up as a christmas present. Im getting a 18 inch fan and a thermanl clutch. Looking forward to quieting the truck up a little. That flex fan has got to go.
68 build thread
Old 11-09-2004, 03:19 AM   #8
70short
When you get it in let me know how it works out THANK YOU
Gary
Edel 600 cfm carb
HEI
shorty Headers
4/2 Drop
"CHEVY RULES"
Old 11-09-2004, 12:24 PM   #9
mdazb
mdazb's Avatar
How much is that going to cost?
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 11-09-2004, 12:54 PM   #10
skokie
skokie's Avatar
The fan is 33.39 and the clutch is 39.95 so around 80 for both.
68 build thread
