transmission linkage assembly picture needed
Anyone have any pictures of the shifter linkage at the transmission (TH350)? I took mine off to R&R the transmission now I can't get it back together properly. Looks like the part that mounts to the transmission shaft is worn and possibly the end of it has broken off. Should the ends be the same length? one end of mine has a hole for a cotter pin the other end is shorter and has no hole. That would be then end i think a piece has broken off.
Lastly is this a common replacement part from a parts store.
