Old 10-27-2004, 04:23 AM   #1
Goober86442
4x4 conversion
Hello I have a 1964 chevy c-20 2wd custom pickup and would like to know what I need to do to convert the 2wd to a 4wd and what donor truck I should use for this? also where can i get a lift kit for my truck?
Thanks for help,
jr.
Goober86442 is offline   Reply With Quote
Old 10-27-2004, 10:20 AM   #2
Mudder
Mudder's Avatar
It has pretty much been determined here that its easier to swap you body over onto a 4x4 chassis. You can swap the parts over from a donor but its a pretty big job. Tuff Country lifts are pretty popular here and can be found in all 4wheel drive magzines or most 4x4 suppliers on the net.
Welcome to our forums.
Mudder is offline   Reply With Quote
Old 10-27-2004, 05:03 PM   #3
Goober86442
I did look at the tuff country lift kits but they dont have one for the year of my truck also I have coil spring suspension. How big of a job is it? Like what needs to be done.
thanks.
Old 10-27-2004, 05:27 PM   #4
dregs454
Killin' Time
dregs454's Avatar
In my opinion, converting a 2wd to a 4wd chassis is totally the wrong way to get a 4x4, unless you want to do it for a challenge, or to say u did it. There is a HUGE number of things you would have to change, front and rear suspension, including steering, transmission.... it would be much easier to swap the body onto a 4x4 chassis, or even easier, just buy a 4x4 if thats what you want
NEED CORVETTE
1972 GMC C20
350, SM465, HEI
Dynomax headers and 2.5" duals
dregs454 is offline   Reply With Quote
Old 10-28-2004, 12:58 AM   #5
1FaastC10
1FaastC10's Avatar
"good highway gears" and a heavy 3/4 ton truck are a bad idea.
1FaastC10 is offline   Reply With Quote
Old 10-28-2004, 01:03 AM   #6
1969 GMC
1969 GMC's Avatar
seeing as how older 1/2 and 3/4 ton trucks are basically the same except for the springs and the rear axle, would you please care to elaborate on this unfounded comment?
I agree with dregs, the hassle is just not worth it. 4x4 trucks (or even better yet, cheap stripped 4x4 frames) are not rare or anything. Good luck.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 10-28-2004, 03:42 AM   #7
Goober86442
what about just lifting the truck, any lift kits for it? I know I what to convert to power steering and front disk power brakes. Whats a good donor truck for that?
Thanks for help.
Old 10-28-2004, 09:32 PM   #8
YankeeWhite
Anyone ever put the 64-66 swb 2Wd body on a 73-87 swb 4X4 frame?
1964 Impala 2dr Hdtp
1963 Nova 2dr sedan
1964 Impala 4dr sedan
YankeeWhite is offline   Reply With Quote
