Old 10-27-2004, 12:19 PM   #1
FatGuy
FatGuy's Avatar
AC/power steering mount w/ headers
I apologize if this is a dead horse. I searched and found only replies for early trucks with this problem. I need to add headers to my truck because the block I used was early and my truck is '86 and alas no dipstick. I am trying to figure out which ac bracket I need that will also allow for the power steering adjustment. I am sure it is a typical part but I am a computer guy and thus have now idea where to look to make sure I order the correct parts. The bracket I am needing replaces the AC mounting bracket that used the exhaust mani bolt near number 1 Cyl.
FatGuy
aka TINY
'86 GMC SWB
FatGuy is offline   Reply With Quote
Old 10-27-2004, 12:37 PM   #2
bigblock73
yeller
bigblock73's Avatar
Have you checked out Alan Grove?
http://www.alangrovecomponents.com/
I will be using their brackets for my big block.
bigblock73 is offline   Reply With Quote
Old 10-27-2004, 05:32 PM   #3
FatGuy
FatGuy's Avatar
Is the 86 model a long pump or a short one?
FatGuy
aka TINY
'86 GMC SWB
Old 10-27-2004, 05:39 PM   #4
Jonboy
Slots go on anything!
it will be the long water pump style.
1974 Jimmy- 5.3/4L80e/NP241
Old 10-27-2004, 05:43 PM   #5
Prerunner1982
Prerunner1982's Avatar
you can use the original bracket and just cut the ear that goes over the pipe off. and still use the front mounting bolt.
here is a thread with pics that may help you out...
http://67-72chevytrucks.com/vboard/s....php3?t=109774
Prerunner1982 is offline   Reply With Quote
Old 10-28-2004, 10:19 AM   #6
FatGuy
FatGuy's Avatar
So are you not going to put that bracket back on? If you are not or if anyone has an extra one I would like to buy it so I can get it ready before I have my truck apart. Pre do you live at 15th and Kelly in Edmond? I used to live in that neighborhood and I remember a white SWB.
FatGuy
aka TINY
'86 GMC SWB
Old 10-28-2004, 12:27 PM   #7
Prerunner1982
fatguy, actually the truck you remember is Brad2s.. i use to live at 15th and western and i work at 15th and santa fe...i have lived all over edmond now.. my truck use to be brown and tan... now its just primer grey.
i plan on putting the bracket back on when i get around to redoing my A/C...
do you not have the bracket at all? its not all that hard to modify.
Old 10-29-2004, 12:02 AM   #8
FatGuy
FatGuy's Avatar
I want to get one and then mod it and get it power coated and have it ready when I get ready to do my swap. That way I dont have to either have the truck in pieces for long or hurry and do the mod. I figure there are plenty of these laying around from people ditching their AC but I might be wrong. If I cant find one here I am sure I can get one from a junk yard.
FatGuy
aka TINY
'86 GMC SWB
Old 10-29-2004, 10:55 AM   #9
Prerunner1982
yeah, i have seen many at caseys CCC, maybe pull a part but there werent as many 73-87s there. i like pull a part better cause you can get what you want... the other places i have been can be pissy and try to sell you the whole front clip if all you need is a light bezel.
