Old 10-28-2004, 09:48 AM   #1
kriss@augustmail.com
Brake hiss...
Help...
I'm having a little brake trouble on my '87 burb. When I depress the brake pedal, I hear a hiss that sounds like a small vacuum line hissing air. This persists about half the pedal travel and I have no brake power. Then on the bottom half of the travel, the hiss stops (mostly) and I get brakes. There is a place along the travel that I can hold the pedal at and get a constant hiss and no brakes at all. What is this?
-Kris
kriss@augustmail.com is offline   Reply With Quote
Old 10-28-2004, 11:45 AM   #2
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
i would bet its your brake booster
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 10-28-2004, 05:37 PM   #3
Bad Karma
Magnificent bastard
Bad Karma's Avatar
It is your brake booster. I had the exact same problem, put in another one with a 12-month warranty, and 13 months later it did it again @#$%*^%$. I was so excited... If its the first time you've changed it, you have my sympathies.
Also, if your master cylinder is leaking into the booster, that will kill it.
1977 Big Block Burb
Bad Karma is offline   Reply With Quote
Old 10-29-2004, 08:40 AM   #4
88Jimmy4x4
88Jimmy4x4's Avatar
Yes, its the booster, or the little plastic piece that the hose connects too.....pretty common for the to crack with heat/age and they arent very expensive....check that and the hose for leaks first (it may be dry-rotted).
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-29-2004, 09:21 AM   #5
Thanks...
Thanks for the info y'all. Is this piece inside or outside the firewall... I've never replaced one, but I have replaced my master cylender 3 times
-K
Old 10-29-2004, 10:58 AM   #6
Bad Karma
Magnificent bastard
Bad Karma's Avatar
The plastic piece is a check valve that is located on the booster in the engine compartment. It has a hose that runs to a vacuum source (mine goes to the carb).
1977 Big Block Burb
Old 11-01-2004, 09:16 AM   #7
88Jimmy4x4
88Jimmy4x4's Avatar
well.................did you fix it?
1991 GMC Jimmy 4x4
Old 11-01-2004, 11:36 AM   #8
Not yet... I'm a big Halloween guy and was working some Haunted Houses. I'll take a look this coming weekend and keep ya posted.
Thanks,
-Kris
