10-28-2004, 10:40 AM | #1 |
Resident Curmudgeon
Pic needed. 67 (or earlier) owners with I6 engines
Anybody have a 67 or earlier with a I6 and original one bbl carb/choke setup? I'd like a picture of the choke cable and bracket attached to the carb. 68 and later carbs are different so it must be pre-68 with an I6. Thanks
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
10-28-2004, 10:46 AM | #2 |
67 is sold
Not sure if these will help. This is the setup that was on my '67
10-28-2004, 10:50 AM | #3 |
Resident Curmudgeon
Awesome, want to sell that bracket attached to the carb for the choke cable?
10-28-2004, 10:58 AM | #4 | |
67 is sold
10-28-2004, 11:09 AM | #5 |
Resident Curmudgeon
Thanks. Anybody else have one? Note that carb is different than those found on 68 and later. I can make something work but there is no substitute for OEM
10-28-2004, 11:16 AM | #6 |
hmm...
I wish I had a good pic of it... The cable housing bolts to the carb where the choke should be, and runs like in those pictures to the spot on the firewall corresponding with the dashboard.
This is the only pic I have of my engine...the cable you can see on the other side of the master cylinder and is the highest thing on the firewall over there.
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
10-28-2004, 11:23 AM | #7 |
Resident Curmudgeon
Thanks, the circled thing is what I'd like to have
10-28-2004, 09:16 PM | #8 |
i might have one i will have to check! i am putting in a 72 motor and carb so i am wont need it if i can find it!
10-28-2004, 09:24 PM | #9 |
sorry dude its MIA!
10-29-2004, 09:18 AM | #10 |
I have one from a 66 GMC w/250/Rochester B model. PM your address. Brian
10-29-2004, 09:46 AM | #11 | |
Resident Curmudgeon
