Old 10-28-2004, 03:13 PM   #1
HeavyD
HeavyD's Avatar
PB Booster bracket question
Hi. I just received my used PB booster assembly and have a question about the brackets on the booster. Attached on the driver side bold/nut that hold on the master cylinder is 2 support brackets, one short and bending toward the front, and one long going to the rear of the truck. What are these brackets for? I have seen other trucks boosters and they did not have these that I can remember. It is going on a 1970 GMC 1/2 ton 2wd. I would post pics if I could get something besides a red X to appear where the pic should be.
Thanks everyone.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 10-28-2004, 03:34 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
The long, rearward pointing one is a brace to spread the stress load on the firewall.
The short, frontward facing one should be for the proportioning valve to bolt to.
Old 10-28-2004, 03:41 PM   #3
HeavyD
HeavyD's Avatar
Thanks, Tx. I should use these brackets then? Did all our truck originally have them?
Old 10-28-2004, 03:44 PM   #4
Tx Firefighter
Yes, absolutely use them.
Here's mine. I pieced the part together. I still don't have the proper braces to go down to the firewall. I just have the one for the proportioning valve.
