Old 10-28-2004, 05:49 PM   #1
Chevyguy111786
fuel gauge past full??
I just replaced my Tank Selector valve and now when i switch to the right tank, it reads way past full...and when i switch back to left...it reads normal...which is empty at the moment. what would cause this?
Chevyguy111786 is offline   Reply With Quote
Old 10-28-2004, 06:43 PM   #2
76bonanza
76bonanza's Avatar
Bad ground would be my guess
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 10-28-2004, 07:10 PM   #3
rolson1039
check your connections on top of the sender of the tank. theres one you can see right through the bed/cab space that is what makes the one in my truck go nutty. I used a little foil on my truck and it worked out well
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 10-28-2004, 08:43 PM   #4
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
When you open circuit the gage sending wire, it will peg past full. I would bet on the ground on that right tank too.
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 10-29-2004, 07:25 AM   #5
cochran63
cochran63's Avatar
With the current gas prices I haven't seen my guage past full in over a month... MY truck was doing hte same thing. I traced the wire that goes to the sendng unit and it was cut into by the edge of the firewall. It looked like it had been cut for years.
Youth soon passes away, but immaturity can last a life time.
cochran63 is offline   Reply With Quote
Old 10-29-2004, 05:16 PM   #6
cliffsta
Stepsides RULE
cliffsta's Avatar
When its fixed, it should still go a little past full and empty, or at least mine does
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 10-29-2004, 09:55 PM   #7
Chevyguy111786
i'll check that in the morning....thanks guys!
Old 10-30-2004, 07:07 PM   #8
Paradise Ridge
Paradise Ridge's Avatar
Ahh yes, But........
Does anybody happen to know what color the ground lead is?
BOTH the tanks on my '82 K30 never leave the 3'oclock position and I havn't had a chance to crawl around in the mud underneath it yet.
Thanks!
Scott
Paradise Ridge is offline   Reply With Quote
Old 10-30-2004, 09:31 PM   #9
ElGracho
ElGracho's Avatar
The grounds are black and terminate on the frame rail close to the tank senders. They are held by a bolt with a star washer on it.
Old 10-31-2004, 05:42 PM   #10
Chevyguy111786
ground was good, my gauge works, just reads past full when filled up...like at the 3 oclock position, but reads empty when empty...i think...haven't gotten that far yet, but it read empty before i filled up and i put in about 19 gallons
