10-28-2004, 07:27 PM | #1 |
help finding p/w switch bezels
I just picked up an 83' gmc. It needs a driver side power window switch bezel. Someone already had it glued on,,, the switch now wants to fall down the door panel. I have looked at a couple of places (not all) without any luck. They sell just the switch without a bezel. Does the dealer offer these??? or anyone elseknow where i can get these???
10-28-2004, 07:43 PM | #2 |
Professional Grade
Not so sure what you mean by a switch bezel?
Can you get a picture? If all you need is a switch, I may possibly be able to find a couple at the local wrecking yard
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
10-28-2004, 09:53 PM | #3 |
No pics,,, it's the chrome plated square plastic piece that holds the switch to the door panel. The tabs are broken on mine
10-29-2004, 11:08 AM | #4 |
try your local auto parts store... (auto zone, oreillys, checker...etc)... most will have what is called a "HELP" section, where they have the switch bezels, door strikers, headlight adjustment screws....mostly small misc stuff that usually breaks.
10-29-2004, 11:38 AM | #5 |
Unfortunately, Autozone and O'reillys doesn't carry just the bezel for the switch. They both have the complete switch assembly, want to say it goes for $20 or $25. Haven't seen just the bezel piece anywhere.
Paul 1984 Chevy C-10 *LWB/305* |
10-29-2004, 12:35 PM | #6 |
i will have to drop by AZ and check... i swear i have seen just the bezel, but could be wrong... now you got me wondering..
10-29-2004, 12:40 PM | #7 |
Slots go on anything!
I am pretty sure you can only get the switch as one piece. If you take off the bezel, the switch can fall apart.
1974 Jimmy- 5.3/4L80e/NP241 |
10-29-2004, 01:44 PM | #8 |
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
10-29-2004, 02:31 PM | #9 |
thanks alot guys i took a gamble and bought a switch and bezel from a nearby yard for $5 looks and works good.
10-29-2004, 05:53 PM | #10 |
Try a chevy dealer
Sean Midwest All Truck Nationals, Riverside, MO - 2008 - 2015 |
10-30-2004, 11:47 AM | #11 |
The dealer wanted $25.00 just for the bezel.
