10-28-2004, 10:34 PM | #1 |
column shifter
I am thinking of buying a billet column shifter and turn signal arm.
How do you install the column shifter? Also has any one bought these? Found some on ebay for 29.95 Thanks
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
10-28-2004, 10:55 PM | #2 |
I think they're just threaded on there. Some of them might have a set screw if I remember correctly? I have an idea for a column shifter I need to fiddle with. You know those handles on the beer taps at the bar? I want to use one of those for my column shifter. My dad gave me the idea about 10 years ago and I've never followed up on it. I'll post a pic if I ever get around to doing it.
10-28-2004, 10:59 PM | #3 |
This would be the whole arm not just the handle.
10-29-2004, 10:08 AM | #4 |
oops... my bad, tired last night and didn't read your question carefully enough.
10-29-2004, 10:39 AM | #5 |
Slots go on anything!
I think you can just drive the pin out and pull the shifter arm off.
1974 Jimmy- 5.3/4L80e/NP241 |
10-29-2004, 07:19 PM | #6 |
Yeah just pop the pin out I put a later model in my 85 If you have a hard time geting it back in try different angles
I found that having the gearshift pulled back towards you helps .. As there is a spring in there you have to get the lever past. |
10-29-2004, 07:27 PM | #7 |
Thanks for the help.
