Old 10-29-2004, 05:10 AM   #1
modmach1
modmach1's Avatar
Lowering Question
My truck is lowered 4" with Belltech shackle kit
Well i took two weeks and the rear end said bang.. then i mounted a new one, and yesterday i heard some sounds in the rear end when i put it in Reverse. The hole car rocks.. So my question is: when dropped 4", must i then shorten my driveshaft`? It wasent easy mounting the drive shaft after changeing the rear end..
http://www.moldestuket.com
1971 Mustang Mach-1 429 CJ-R
1973 Mustang Mach-1 289
1975/71 Pontiac Firebird Formula 400
1978 Chevrolet C-10 Fleetside Longbed Scottsdale
1980 Pontiac Phoenix
modmach1 is offline   Reply With Quote
Old 10-29-2004, 07:56 AM   #2
SCOTI
SCOTI's Avatar
I have a flip kit + dropped shackles. I didn't alter my driveshaft length & haven't had any problems after almost 2yrs on the road. What shape are your u-joints in ?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-29-2004, 08:19 AM   #3
bigblock73
yeller
bigblock73's Avatar
I have the Bell Tech 4" shackle/hanger kit...never experienced any problems, I had mine on the road three years before I tore it apart.
I am with Scoti...check the U-joints.
bigblock73 is offline   Reply With Quote
Old 10-29-2004, 09:13 AM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Maybe you just have the wrong driveshaft?
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-29-2004, 12:27 PM   #5
CLASSIC87'
OL BLUU
CLASSIC87''s Avatar
I have had my springs dearch 4" inches, a 2" shackle, and I have just recently removed the "heavy half" spring for another 1" or so. Anyways.... I have not had any problems with the drive shaft being to long or making any unusual noises.
Anthony
CLASSIC87' is offline   Reply With Quote
Old 10-29-2004, 01:45 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
Check your u-bolts
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 10-29-2004, 03:32 PM   #7
loblazer
loblazer's Avatar
Check your pinion angle. Must not be more than 2 degree difference positive or negative or you will take out the u joints and/or the rear gears.
I have a 5" flip kit with C notch in my 2wd Blazer. Took out 2 sets of u joints before I realized the pinion angle was wrong.
Luckily I discovered the trans mount was crap and was throwing my angle off. When I replaced that with a new one, the angle was 1 degree. Over 4000 miles now with no problems.
Check your trans mount in the crossmember and see if it is at all worn down. If so, replace it and then check your angle with a protractor gauge. Any part store would have one.
If it is still off, you can get pinion shims from any chassis shop or 4x4 specialty shop. Come in 1 degree up to 6 degree sizes so you should be able to get dead on. Do not go to zero though, it must be 1 or 2 degree to give some flex on acceleration.
October TOM
Doug
loblazer is offline   Reply With Quote
Old 10-31-2004, 08:49 PM   #8
piecesparts
Parts and more parts
piecesparts's Avatar
Length of the driveshaft is important. If the driveline is to be centered in the transmission output shoft seal, then you may have to shorten it. I had to on a couple of trucks. I believe that your problem would be at the tranny before you would have problems with the rearend, if it was to long. The ouptput shaft would be leaking or the tube would be damaged before that heavy rearend would give any.
piecesparts is offline   Reply With Quote
