10-29-2004, 05:33 PM | #1 |
402 Question
Was The 402 Bored Out From The Factory? If Not Then How Does It Get The Extra 6 C.i.'s From The 396?
https://www.ebay.com/itm/29620574751...mis&media=COPY |
10-29-2004, 08:48 PM | #2 |
huh ???
The 402 is a factory .030 over bored 396...
Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
10-29-2004, 09:26 PM | #3 |
Yea, the reason for this was due to some bad cores they had. They bored them .030 over to clean up the bores and still use the blocks.
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block |
10-29-2004, 10:40 PM | #4 |
no theres a lot of myths about why the bored the most logical and most realistic is because of the 400 small block gm didnt want a small block that was bigger than a big block it doesnt look good so they bored em out. theres other stories about a flood from a fire sprinkler all kinds of neat stuff
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
10-29-2004, 11:21 PM | #5 |
I read somewhere that Chevy did it to pick some of the lost HP from new emission controls-but they still called it a 396 in the Chevelles, but my 72 Burb had 400 emblems on it.
10-29-2004, 11:38 PM | #6 | |
Cantankerous Geezer
Fred There is no such thing as too much cam...just not enough engine. |
10-30-2004, 12:40 AM | #7 |
its all about the +6 inches
And they called it a 396 in the performance cars becouse the 396 had already earned respect.
I agree with cableguy, I think it was inner corperate politics. If you were to look into it, (IIRC) the 400 small block is also a 402...which if this is true, it would just back up the numbers game they may have been playing on the big block verses small block. |
10-30-2004, 01:19 PM | #8 |
FYI They didnt start to make a 400SB till 75 I think
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters |
10-30-2004, 01:24 PM | #9 |
Got Light Emitting Diode?
my sb400 came out of a 73 caprice. i know when they are bored .030 over the actual c.i.d. is 407 but i have never heard anyone call it that so 406 it is
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car) 1993 Cherokee work ride/weekend wheeler |
10-30-2004, 03:22 PM | #10 |
Small Blocks
265..........3.750 bore X 3.000 stroke...265.0 283..........3.875 bore X 3.000 stroke...283.0 302..........4.000 bore X 3.000 stroke...301.7 305..........3.740 bore X 3.480 stroke...305.8 307..........3.875 bore X 3.250 stroke...306.6 327..........4.000 bore X 3.250 stroke...326.7 350..........4.000 bore X 3.480 stroke...349.8 400..........4.125 bore X 3.750 stroke...400.9 Big Blocks 396..........4.095 bore X 3.760 stroke...396.1 402..........4.125 bore X 3.760 stroke...401.9........the big block is bigger .010 427..........4.250 bore X 3.760 stroke...426.7 454..........4.250 bore X 4.000 stroke...454.1 I know that there are others.......mostly insignificant though. I am currently looking into building a "backward of GM's way" 427 by using a 454 crank 4.000 and a 402 block 4.215 ...427.6. Thus being a stroker 427 rather than a big bore 427. I have yet to mock the crank up to see if I have rod clearence though. The 402 block is different near the bottom of the bores, so I'm not 100% that this will work. BTW, has anyone done this? does it in fact work? |
10-31-2004, 12:02 AM | #11 |
The 400 small block was made from 70 untill either 79 or 80.
10-31-2004, 08:27 PM | #12 |
Looking thru a GM Tune Up manual;specs are listed for the 400 engine for the following years.-- Chev auto- thru 1976; Chev/GMC trucks- thru 1977; Olds- thru 1975 and Pontiac thru 1978.
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
10-31-2004, 09:21 PM | #13 | |
Binder Rep
Through a year doesn't help... because we need to know what year it started in! And I guarantee that it wasn't around in 1940. |
10-31-2004, 10:52 PM | #14 |
Had A stock originial 1970 Monte carlo with a small block.. 1970 was the first year
10-31-2004, 11:04 PM | #15 |
Hmmm, acording to the red book, the chevy trucks could be had with a 400 untill '80.
