10-30-2004, 12:02 AM | #1 |
Life, Be In It.....
Does anyone have a lowered truck with a one piece drive shaft????
I was wondering how you prevented the one piece drive shaft from hittng the carrier bearing mount cross member. I am sure it is a simple fix, but I want to see how you fixed yours.
In the attached pic, you can see that the drive shaft almost hits the top of the cross member.
Project Name: LEMON DROP. Reconstruction started "December 2000". Projected completion date "Who knows" http://67-72chevytrucks.com/vboard/s...d.php?t=200082 |
10-30-2004, 12:05 AM | #2 |
Life, Be In It.....
another pic
10-30-2004, 12:06 AM | #3 |
Watch out for your cornhole !
I've had several short wheelbase trucks lowered with 1 piece shafts.
Remove any old carrier bearing junk and there should be plenty of room.
10-30-2004, 12:08 AM | #4 |
I just saw your 2nd picture.
Forget what I said. My trucks were all just lowered. Your custom rear subframe setup is a whole different ball of wax than I've ever dealt with. You may now resume your regular internet viewing pleasure.....
10-30-2004, 12:10 AM | #5 |
jugernot...I was running into the same problem, so I went with this.....
http://www.earlyclassic.com/tech.asp...%20Crossmember
"SicStee8" Chevy SWB Fleetside, in progress...500 HP 383 w/TriPower, 700r4, 3.73's, Lowered, Shaved Driprail/sidemarkers/handles/ant, Gonna rock!! '96 Chevy Tahoe 4X4 '84 Chevy C/K10 4X4 (FOR SALE) |
10-30-2004, 12:11 AM | #6 |
You could Make a new Top section weld it in then cut out the old one .. Kinda like a C notch.
10-30-2004, 01:16 AM | #7 |
Life, Be In It.....
67chev,
I was looking at that piece today, how much more room did that piece give you?
10-30-2004, 09:03 AM | #8 |
Man that looks great!!!
10-30-2004, 10:46 AM | #9 |
My 68 is very close but has not hit that I can tell. My RestoRod is a little lower & did require trimming the inside/top to gain more clearance. After trimming, the the entire c-member was boxed.
10-30-2004, 08:33 PM | #10 |
Life, Be In It.....
I think I will just have to drill out the rivets and buy the x member from Early Classic.
10-30-2004, 11:59 PM | #11 |
well before you spend a lot of money put a jack under the rear end put jack stands under the frame and remove the coil overs. this will free up your suspention to travel up and down. next jack the rear end up as far as you can and see if the drive shaft touches the crossmember. if it does concider purchasing an aftermarket trans crossmember to bolt in its place. the reason i say this is the crossmember thats causing you problems is no longer holding the trailing arms, it's only holding the 2 halves of the frame together.
i hope this is marginaly helpfull, ondrew |
