Old 10-30-2004, 01:03 AM   #1
skokie
skokie's Avatar
Quadrajet info needed.
I got some questions about a qjet. What are these screws for in the pics?
What does the small vacuum used for?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 10-30-2004, 01:17 AM   #2
1BAD69
1BAD69's Avatar
the one on the fuel inlet side is the fast idle for the choke. the other i'm not sure it may control the the tension on rear lower butterflies.the vaccuum port is for the spark advance
SO MANY TRUCKS SO LITTLE TIME
1BAD69 is offline   Reply With Quote
Old 10-30-2004, 01:32 AM   #3
skokie
skokie's Avatar
Spark advance? Would it have been used for a vac modulator?
68 build thread
Old 10-30-2004, 08:44 AM   #4
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Checked my 66 Impala w/327 that has a Qjet and that vac port is indeed used for the vacuum advance unit.
The item in the first pic on mine is the "gizmo" used for the fast idle. I believe this part may also stop the secondaries from opening if the choke is still on. (cold engine) Not 100% sure on that though.
The transmission modulator line on goes to a block screwed into the intake in between the distributor and carb. My power brakes also connect there.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
