Old 10-30-2004, 01:04 AM   #1
skokie
skokie's Avatar
Horn mounting
What is the stock location for the horn on a 68 1/2 ton? Also where does it get its power from?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-02-2004, 02:50 AM   #2
skokie
skokie's Avatar
Ttt
68 build thread
Old 11-02-2004, 08:23 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It goes on the driver's side of the core support, right above the voltage regulator. It's held on by a 5/16 size bolt.
There should be one wire breaking out of the harness that plugs onto the horn terminal. I can't remember the color of the wire right now though.
Old 11-02-2004, 10:54 PM   #4
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
green i believe
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-03-2004, 02:32 AM   #5
skokie
skokie's Avatar
Think I found it
Think I got it. Its plugged into the bottom of the voltage regulator. Am I looking at the right wire? Its the only green one coming out of the headlight harness that I can see.
68 build thread
Old 11-03-2004, 08:59 AM   #6
Tx Firefighter
Plug it onto the horn and push the button.
Report back!
Old 11-03-2004, 11:47 AM   #7
skokie
skokie's Avatar
Tx Firefighter
Will do that tonight. Just curious as to why the previous owner plugged it into the voltage regulator. I dnt think it matters I have the voltage regulator bypassed and I am using a internally regulated alternator. Will let you know if it honks tonight.
68 build thread
Old 11-03-2004, 01:58 PM   #8
68w/sbc406
68w/sbc406's Avatar
thats funny as hell. i did the same thing when i was putting my truck back together. i was wondering where my horn wire went. i pulled it off and tested it with a light and it lit up when i hit the horn so ............. yeah thats the right wire
Old 11-03-2004, 08:43 PM   #9
skokie
skokie's Avatar
Ok I hooked it up and all I am getting is a clicking noise. Any suggestions?
68 build thread
Old 11-03-2004, 08:47 PM   #10
Tx Firefighter
the clicking is your horn relay under the dash isn't it?
1st, make sure your horn is well grounded.
2nd, disconnect horn wire and run a jumper wire from your battery positive to the wire terminal on the horn. It should honk.
3rd, adjust the horn a couple of times with a non marring hammer (mallet). Don't twist off on it, just give it a couple of little tune-ups.
These steps will likely get you horny.
Old 11-03-2004, 10:11 PM   #11
skokie
skokie's Avatar
How would I check if it is grounded?
68 build thread
Old 11-03-2004, 10:23 PM   #12
Tx Firefighter
Make sure there is clean metal to metal contact between the horn and the core support. I use star washers under the bolt head. They dig through the paint and crud to get a good bite into the metal.
Old 11-03-2004, 11:45 PM   #13
skokie
skokie's Avatar
Thanks Tx firefighter. I will also hit that area with a little sand paper as well.
68 build thread
Old 11-03-2004, 11:55 PM   #14
skokie
skokie's Avatar
Forgot to answer that question. Yes the clicking is coming from the horn relay under the dash.
68 build thread
Old 11-04-2004, 12:01 AM   #15
68w/sbc406
68w/sbc406's Avatar
have you hooked your horn up to just your battery to see if that works??? dont point it at your face and might want some ear plugs if you are in a garage
Old 11-04-2004, 02:13 AM   #16
skokie
skokie's Avatar
Got it working. Just need a good sanding on the spade that the power wire goes to and the area that it bolts down to.
68 build thread
Old 11-04-2004, 08:47 PM   #17
68w/sbc406
68w/sbc406's Avatar
good to hear
