Throttle return spring
Where does the throttle return spring connect to on a quadrajet?
Thaks
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
Still drivin' a Rat Rod
To the bottom of the linkage like this
http://www.pirate4x4.com/tech/propane/Image005.jpg That's how I have mine
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
I just hooked mine directly to the (clevis pin) hole in the end of the throttle linkage rod thingy. Expecially good if yoru still making adjustments.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
Sounds good thanks.
72 BB C30 Super LongHorn
![]() Join Date: Nov 2002
Carb Spring Pic Image
This is from my 72 Longhorn....
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() |
yea...but you don't have a q-jet?
This is a QuadraJet set-up; what makes you think this is not??
Looks like a Qjet to me
![]() May not be a qjet now though,or may not even be his truck ![]()
This is a direct pic taken from my C/30. No disguising the truth!!!
RPOZ11 Why is the cruise not hooked up on the BB?
I removed the cable so one could see the spring present. Installed, the cable would have blocked the view of the spring...
Watch out for your cornhole !
![]() Join Date: Jun 2003
Skokie's truck is a 68, so it will be different than the 72 pictured above The bracket the spring is hooked to won't be on Skokie's truck. The 68 uses a throttle rod, the 72 uses the cable and bracket.
I'm pretty sure Ragenrat was talking about Skokie not having a Quadrajet. Last picture I saw of his engine, he had a 600 Holley on it. Skokie told me via PM he was converting back to toally stock, so I'd imagine he's asking so he'll know how to put the quadrajet onto his truck.
#13 |
Ah Haaaa! You are correct, I do recall this now. Been a while since my pre-72 ownership....Any pics to add please do so!
If I do recall, I believe there was a bracket that possibly came from the thermostat housing? alike Corvette? ![]() ![]()
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS ![]() Last edited by RPOZ11; 10-31-2004 at 09:50 PM. |
#14 |
its all about the +6 inches
Here's mine on the 69, it isn't stock, but it may spark some ideas maybe? The kickdown bracket was fabbed and includes a hole for the throttle spring. (I think the spring looks like crap pulled to the front)
#15 | |
Tx Firefighter You are 100% correct. I got the quadrajet last week from Randy (thanks Randy) I am going to get it rebuilt and put it on the GM intake I got last month.
#16 | |
Got Light Emitting Diode?
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#17 |
Mine also is hooked up to the front, but that's because the throttle shaft bores wore out & had to be replaced, & I figure the factory way (to the rear) is probably why.
