does anybody have the schematics for the taillights on a 67 fleetside? - the wires that come from the front are yellow, green, white, and brown.
Then, the wires that go to the right lense are green, light green and brown. the left have yellow, green and brown -- how do these all work together? - please e-mail to Ivanhakari@hotmail.com |
Old member
I'm not sure about the wiring diagram, but you should be able to figure it out if you take the plug loose at the frame under the bed. There should be a round plug that pulls apart on the drivers side. Turn on the lights and use a test light to check each one. The one that lights is for tail lights. Then cut your light off and just turn on one single light, check them agian and see witch one blinks.Then do the other and right down the wire color and so on until you know what all of them are. Hope this helps. It just takes a while.
------------------ Andy 71's Are for ever!!! or 67,68,69,70,72 http://geocities.com/chevy71tpi/main.html
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
its all about the +6 inches
Brown Parking lights $ License plate
Yellow Left hant turn and brake Dark Green Right hand brake and turn Yellow Back up lights. ------------------ '69 G.M.C. 350/350. Trying to clean up the left over damage from the Dope-Smokin-Old-Man I've been dubbed the Longhorn Freak/Fanatic/Expert, I just hope I can live up to it. FINALLY got the HORNIAC...a '70 one ton Longhorn with a Pontiac 350/350 and lots of 'personality'. Check out The Longhorn Webite. If you need a pic posted, E-mail me at longhornmail@yahoo.com Andy, in Columbus Ohio |
My page has diagrams on it. www.geocities.com/chevroletc1070
Have fun. CoryM ------------------ 1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army
1970 heavy duty C-10 fleetside sport truck. Vancouver B.C. Canada http://www.geocities.com/chevroletc1070 "Take up our quarrel with the foe: To you from failing hands we throw The torch; be yours to hold it high." Lieutenant Colonel John McCrae, Canadian Army |
