Old 10-31-2004, 06:02 PM   #1
70c10
67-72 Addict!
70c10's Avatar
Electrical help- fuel gauge
When I put a test light on my pnl fuse I get no current. I'm not getting current to the fuel terminal either. I just installed a new sending unit 2 weeks ago and the gauge worked great. I also installed a new wire from the tank to the fuse block. My question is what is the terminal under the fuel terminal for?. My test light will light up when I touch it but it's not marked. Any ideas why I wouldn't be getting juice to these 2 terminals ( the one marked "fuel ga" and the one marked "pnl lts"?. All of my other circuits light up fine when tested.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 10-31-2004, 06:05 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
pnl lts will be hot when you turn on your parking lights. use this position for clearance lights, guage lights, or step board running lights.
Try hitting the fuel guage terminal with a digital multi meter before you go any further. If I rmemeber, it was only something like 5 volts on that terminal or something.
Old 10-31-2004, 10:15 PM   #3
70c10
67-72 Addict!
70c10's Avatar
Andy, I will try that. Do you know what the open terminal under the fuel gauge terminal is for?
Jim
Old 10-31-2004, 10:19 PM   #4
Longhorn Man
Hmmm, not sure.
Old 10-31-2004, 10:22 PM   #5
70c10
67-72 Addict!
70c10's Avatar
ok, I was just curious because it's hot. I was thinking about trying that one but didn't want blow anything up!. Thanks
Jim
Old 11-03-2004, 08:35 AM   #6
70c10
67-72 Addict!
70c10's Avatar
Update- Yesterday I found out that little terminal under the fuel terminal is only "hot" with the key on so I tried hooking up the gas tank wire to it and the gas guage went up waaaay past full. So I put the wire back to the correct terminal and the gauge went back down to 1/8 even though it has almost 10 gallons in it. I touched the fuel terminal with the test light and that was the ONLY circuit where the light was dim. That makes sense since you said it was only about 5 volts. This leads me to believe my brand new sending unit might not be so accurate. . As soon as I get the brake lights fixed we will take it on it's maiden voyage to the gas station and fill it up and see what happens.
Jim
