Post Whore
![]() Join Date: Feb 2000
Alternator wiring question
In the FAQ about switching from an externally regulated alternator to internally regulated http://207.44.196.117/vboard/showthread.php3?t=119379 it states:
Now the blue wire, which is just an extension of the brown wire, connects to the tab on the right (number 1 tab). The brown wire runs the the idiot light/gauge in the dash and is there for resistance to the internal voltage regulator. You can not skip this as it tells the regulator what it needs to be doing and when.And it shows this pic ![]() The engine I have put in the K20 uses an internally regulated alternator on the 1989 454. I am using Autometer gauges and am not using the stock wiring harness for the gauges. I won't have an idiot light like on a stock gauge setup. I'm concerned about the above info that says not to skip using the brown wire that is there for resistance to the internal voltage regulator. Do I need to do something with the brown wire to tell the "regulator what it needs to be doing and when"?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Alternator wiring
I had the same problem. I talked to Mark at M.A.D. and he said that you have to have a light so I put a little round indicator light under the dash and it works great.
1980 Chevy Shortbed Pickup 1969 Z28 engine Turbo 350 |
Post Whore
Did you just find the wire in the under dash wiring and tap in there? Should be easy enough. Thanks!
Post Whore
Also, does it just light up if there is a charging problem or does it stay on all the time?
Got Light Emitting Diode?
i hacked my dash and stuffed a tach in where the idiot light is and changed over to an internally regulated alternator. i havent read the FAQ thing but i spliced 2 wires down on the regulator plug(the middle 2) and then put the new style conector on and it works fine. no problems
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
#6 | |
Post Whore
So am I understanding that I take the brown wire and wire it so that it branchs into two wires and hook them to the feeds for an indicator light so it has power on both feeds?
