Old 11-01-2004, 08:08 PM   #1
krue
Designated A-hole!
krue's Avatar
Electrical question for ya'll.
My blower motor has been blowing 30a fuses off and on. The motor will run for a while then the fuse will blow. With the ignition off I disconnected the purple wire from my a/c blower motor. I tested for ground on the spade on the motor and got a reading of .5ohms, the same reading I got when touching the probes together. I tested back through the switch (in HI position) and got a reading of 12.5ohms. What would be normal readings? Is the switch or blower or both bad?
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-01-2004, 09:23 PM   #2
JimKshortstep4x4
Smile
I just checked a couple of blower motors and got .6 and .7 ohms which is very close to your reading on your motor. It sounds like you are loosing contact slightly in your switch but that would not cause blowing of the fuses.
I suspect that you have a blower motor problem and you should be able to check the draw when it is running if you have the right ammeter setup. ( I use an ammeter that read by placing it over the wire).
Jim
Old 11-01-2004, 09:40 PM   #3
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
put a 35 in and call it good
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-02-2004, 02:12 AM   #4
68LSS1
68LSS1's Avatar
Yes, it sounds like your blower motor is tired and pulling too much amperage blowing the fuse. Usually, not always, but usually, a short to ground will blow the fuse instantaneously.
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 11-02-2004, 11:04 AM   #5
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
There is a ? rheostat ? Up under the heater box. Mine was doing the same thing. I found the ? rheostat? thing and replaced it. Heater works like a charm.
Sorry I don’t know exactly what you call it. Its hidden up on the heater box though, just follow the wires you'll find it
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 11-02-2004, 08:13 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
That is a resistor in the heater box...normally they either work, or don't work. (Although, there is the chance that it is at fault)
IMO, I think the motor is getting old and tired. Does it make any squeeling or rumbling noises? Drill a real small hole dead center on the sheet metal of the blower motor. You don't even need to remove it from the truck. There is a raised nipple, drill it in the center, and then put some graphite powder...or spray in the hole. Use a small dab of silicone to re-seal the hole. Do not operate untill sillicone is dry.
If this solves the problem, then your motor is on borrowed time. however, i have seen blower motors fo 5 more years after doing this. Personally, mine is about to hit 4 years on this repair...and still blowing hard too.
Old 11-02-2004, 09:08 PM   #7
krue
Designated A-hole!
krue's Avatar
$13 dollars at O'reilly's for a new blower motor, now I just gotta find the time to install it. Thanks for the help guys!
www.daveramsey.com
Old 11-02-2004, 10:42 PM   #8
Longhorn Man
mannn, last time i checked into a new blower, I was quoted 45 bucks....which is why mine has silicone on the end of it.
Still, it is a quickie that does work.
Old 11-02-2004, 10:44 PM   #9
68w/sbc406
68w/sbc406's Avatar
you like those quickies..................................fixes that is
Old 11-02-2004, 10:49 PM   #10
Longhorn Man
I like them quick AND cheap.
Old 11-02-2004, 11:47 PM   #11
68C15
blood type; Retumbo
68C15's Avatar
but do you like them clean or greasy & bloody? repairs that is.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 11-03-2004, 12:25 AM   #12
Longhorn Man
lol
