Old 11-01-2004, 09:27 PM   #1
RapidRide2
opinions on posi brands?
I am going to be rebuilding my 83' gmc rear diff. soon. I am going to switch from a 2.56 to a 3.73 posi. What are your opinions on factory gm,, auburn,, eaton,,, and richmond powertrax. This truck will be street driven with about 300 h.p. I want good street manners fronm the posi yet reliable and strength. I only want to do this once. p.s. has anyone ever retrieved a rearend from a junkyard with good success????? Thanks in advance. Matt
RapidRide2 is offline   Reply With Quote
Old 11-02-2004, 12:35 PM   #2
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Factory GM used Eatons and for yours it used the Gov-Loc. Auburns I don't care for because they are cone type and when they wear, the destroy themselves and are not rebuildable. I heard they were changing them, but.... I am using Eatons LSD on mine, it is what came factory in the 12bolts.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-02-2004, 01:28 PM   #3
7T7
Regular guy
7T7's Avatar
Have you looked at the DETROIT TRUE-TRAC?
After looking at all the different limited slip differentials on the market, this looked like the best.
No clutches that burn out, easy to install (if you weren’t changing gears) and good street manners.
Tractech
'Frank'
77 Silverado
18 & 20 American CL205s
Edelbrock MPFI, 700r4, Baer Brakes
9" F@rd rear, Vintage air, Bags etc etc..
7T7 is offline   Reply With Quote
Old 11-02-2004, 01:48 PM   #4
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
The auburn i sold was a clutch and spring type. I didn't know auburn made a cone type.
But as Chris states you may want to steer clear of the cone type as they are not rebuildable.
I have seen these (cone type) fail at the track too. So durablity is also an issue.
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
Old 11-02-2004, 02:08 PM   #5
Captkaos
Captkaos's Avatar
Denny, I wanted to verify my info before I commented, but Auburn does have a clutch/spring type, but the clutch is the cone clutch, so all of them are cone types for the Limited Slip's
http://www.auburngear.com/aftermarke...differentials/
The ended up not changing the design apparently, but are offering a D-REX program that replaces the case and all other componenets: http://www.auburngear.com/aftermarket/drex/
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-02-2004, 08:40 PM   #6
DennyB
DennyB's Avatar
Chris, Thanks for the clarification. I thought the auburn had a clutch and friction disc setup.
It’s good of them to provide the D-REX program.
The only problem I see with that is the D-REX program is only good for 4 years. After that, what’s the cost?
I also want to clear up one more thing. The units I have seen break at the track are powertrax No-Slip units.
They seem fine for street use but a high HP engine with sticky tires seems to be a bit much for them.
But then again, I don’t think this application is what there designed for.
Thanks again for the correction Chris.
Denny
I.M.O.M,W,J&C
Patriot Guard Rider
Old 11-02-2004, 08:47 PM   #7
DennyB
DennyB's Avatar
7T7, The TRUE-TRAC you provided a link to is very intresting.
Do you know any one that has used it?
I.M.O.M,W,J&C
Patriot Guard Rider
Old 11-02-2004, 09:35 PM   #8
7T7
Regular guy
7T7's Avatar
We put one in a 69 camaro about a year ago and have had no problems with it. The guy hits about 12 autocross races a year.
We were looking for something that could handle big horsepower and still be good for autocross.
The Truetrac was definitely the ticket!
I like the way it worked in the 69 so much, I put one in my current 77 project truck. (which still is in the works)
The cheapest place I found to purchase a Truetrac was "4 Wheel Parts". $415
'Frank'
77 Silverado
Old 11-03-2004, 12:12 AM   #9
TIMSPEED
TIMSPEED's Avatar
I desperately wanted the TrueTrac, but they don't make it for a Series3 12-Bolt, only Series4...so I went with the Eaton Posi, and it's been great so far.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-03-2004, 08:48 AM   #10
DennyB
DennyB's Avatar
I'm moving this to the Engine & Drivetrain board with a redirect. I will also stick it to the top for a while so it does not fall off the page and you can find it.
It will get better exposure there for additional answers to your questions.
Plus that is where it belongs
I.M.O.M,W,J&C
Patriot Guard Rider
Old 11-03-2004, 10:57 AM   #11
Primed67
Primed67's Avatar
I'm running an Auborn Pro Series chunk. It has been in the truck for 6 years now and took a lickin. I busted a set of Richmond gears but the Aurborn chunk is still in great shape and working just like it was designed.
1969 Chevrolet SWB Stepside
1959 Chevrolet apache * Sold
1967 Prostreet Chevy SWB Fleetside *Sold
2014 1/2 ton Crew Cab Chevrolet 4x4
Primed67 is offline   Reply With Quote
Old 11-03-2004, 01:32 PM   #12
72k5
72k5's Avatar
Eaton makes 2 versions of their posi. One is a HD unit with more (22 vs. 14) clutch plates and stronger preload springs. The HD unit has much better grip, but is more likely to chatter and chirp the tires in turns. I believe the Moroso unit (Eaton rebadge) is the HD unit only, but you might want to confirm that if you order one. The standard version is what you got as an option from GM, unless you are getting a Corvette (not to be confused with the GovLock that GM also provided as an option in past and current years - the GovLock is a whole different animal).
The HD version never failed me, traction wise, even rockcrawling. I have a feeling that the std. version might have, it I had given it the chance, but it was much calmer on the street.
Point is - make sure you get the version you want if you order an Eaton. BTW - You can put a HD clutch and spring kit in a Std. housing if you want to upgrade your OE Eaton.
I can confirm that it is possible to break the spiders in these, but I think they are as strong as anything else in that size diff.
350 ETec 170 heads, Performer, HEI, Holly TBI, 700r4, 14 bolt rear, F&R lockers, lots of off road improvements.
72k5 is offline   Reply With Quote
Old 11-03-2004, 05:19 PM   #13
boraxman
Keepin an eye out
boraxman's Avatar
I did the 12 bolt in my truck w/ new Eaton posi & 3.42 gears, new axles, seals bearings, labor, brakes for about $1300....works great
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 11-04-2004, 01:35 AM   #14
shadetree
shadetree's Avatar
Good thread. I'm saving my money for an Eaton posi, and 3.42 ring and pinion, can anyone advise if setting up a 12 bolt ring and pinion is as difficult as it looks?
1970 long fleet, 355 4 speed, primer, walnut goodies
shadetree is offline   Reply With Quote
Old 11-04-2004, 01:43 PM   #15
72k5
72k5's Avatar
Well, define difficult... If you have a puller for the carrier bearings, a press and associated items to remove and install the pinion bearing, and plenty of shims to choose from, no, it's not too difficult. Lacking one of the special items above could make for a real PITA job. Like so many of the things we do, having the right tools makes all the difference.
Old 11-05-2004, 02:14 AM   #16
shadetree
shadetree's Avatar
I have no press, but I do have everything else. I do have a good machine shop available, though, that has a press. Setting up a ring and pinion is about the only thing I haven't done in my many years of wrenching.
Old 11-06-2004, 12:55 PM   #17
72k5
72k5's Avatar
Well, if you have everything else, with a little luck, you might be able to get the pinion shims right on the first shot, so only one trip to the machine shop. Be forewarned that you will probably need to pull and reinstall the carrier bearings a number of times to get everything right. That takes just the right two jaw puller, and a small impact gun, or it can be miserable.
One thing many people miss is that they pattern the gears without a load on them. You need to somehow provide resistance, so that you have to turn the pinion firmly with a wrench when patterning. Unless you do, the pattern will be meaningless.
If you can do it so that you are not in a hurry to get it done, I say get a good set of instructions and go for it. Setting up diffs is probably one of my favorite things to do. If you want to do one and really enjoy it, do a 14 bolt. They have the threaded collars and you can just dial the adjustment in. Sweeet!
The first diff you do will take 4X as long as the 4th one you do. Have fun.
Old 11-07-2004, 01:00 AM   #18
shadetree
shadetree's Avatar
Thanks for that responce. I'm going to hone out an inner pinion bearing, to get the depth right, being able to slip the honed out bearing on and off. Then have a new bearing pressed on when I'm ready. Thanks for the info on loading the gears, I'd never have thought of that. Good solid info, thanks
