Old 11-01-2004, 09:59 PM   #1
toolpimp
too many toys
toolpimp's Avatar
Exclamation dana 44 front diff.
i have a 71 gmc 3/4 ton 4x4. It has 1 ton spindalls on it and im having a hard time finding drumsfor the front I was told that my truck has 1 ton susp.. ?? dana 60 in back .dana 44 in front with 1 ton spindalls?? Previous owner say he bought it new from dealer in saskatchewan.i found shoes for the back but no drums. I cant seem to find drums or shoes for the front.... Ive exhausted my suppliers, any suggestions??
if we were all fatter we'd be closer together
1971 gmc 3/4 4x4 383 stroked
1968 1/2 2nd owner 4bbl 6cyl
1969 gmc 3/4 4 sale 350 4bbl 4spd
1969 chev 1/2 lowered 5 spd 454 4bbl
1947 chev coupe
2002 harley flhtcui
6 -67-72 my parts
toolpimp is offline   Reply With Quote
Old 11-01-2004, 10:17 PM   #2
Destructo
shouldn't a 71 have come factory with disc fronts?
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 11-01-2004, 10:59 PM   #3
clarkjw24
I like cheese
clarkjw24's Avatar
Drop the drums and go disk brakes. 1 ton spindels would only fit a D60 I think. People see 8lug and assume 1ton.
Cruiser: 1972 K5, 400/TH350/NP205, D44 and 12Bolt, 35 TSLs.
Trail rig: 86 K5, 350 TBI, SM465/NP205, 5.13s, 14ff locked, h1 beadlocks, 42" TSLs, 64" rears, 56" fronts, D60 locked, 35pline, drive flanges, crossover, hydro assist, OBA.
Tow rig: 2002 F350 PSD CC Dually FX4, chipped, cold air intake, BFGs
clarkjw24 is offline   Reply With Quote
Old 11-02-2004, 08:11 AM   #4
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
If you do have drums up front w/ open knuckles then somebody swapped in a 1970 3/4 ton dana 44 axle on you. This is a one off year and drums are hard to come by. I bought my front drums for my 70 off of Jerry Moss, used. There was no 1 ton suspension for the 4wds. Though, w/ an H072 in the rear w/ 13" brakes, you could haul quite a bit.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-02-2004, 10:06 PM   #5
toolpimp
too many toys
toolpimp's Avatar
diff problem:
the serial # is ke2341z60844. It is a dana 40 with 1 ton susp. Camper special is what i was told
1947 chev coupe
2002 harley flhtcui
6 -67-72 my parts
Old 11-03-2004, 01:35 AM   #6
Rod
You got a 1970.
Heres a post I made for you on decoding 70-71 GMC vins and hub pics. http://207.44.196.117/vboard/showthread.php3?t=126065
I'll post the vin one here too.
Check your private messages too.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-03-2004, 10:28 PM   #7
white82
White 82
white82's Avatar
u better check the tittle on that thing!!!!!
1966 GTO 455 e-heads, 1982 Chevy k10 4'' lift 33’' tires, 2008 Pontiac g6 v6
white82 is offline   Reply With Quote
