Old 11-02-2004, 02:11 PM   #1
schwab7
1996 GMC truck keeps stalling
After replacing my intake manafold gasket I started having a problem with my truck stalling. It is an intermittent problem. While driving my truck will sputter and i will get no gas to the engine while I hit big bumps, sometimes the truck will completely die while driving. Other times the truck will die when i am coming to a stop. I tested my fuel pump and was getting 40 psi but that was when i was obviously stationary. While driving im not sure if the bupms that i am hitting are knocking the pumps wiring loose or something. Ill take any ideas. Thanks for the replies.
1996 GMC 1500 V8 5.7 350
schwab7 is offline   Reply With Quote
Old 11-02-2004, 04:50 PM   #2
GM-TECH
I was thinking that the filter was clogged and after driving a while the system was starving for fuel.Did not know it was when you hit a bump. Sounds like a loose wire somewhere. Good Luck
I Have No Competition, Only CompetitorsThat's Why I Have Rear View Mirrors, So I can See You
GM-TECH is offline   Reply With Quote
