11-02-2004, 02:56 PM | #1 |
Carb cleaner?
I have my carb all apart to try a first rebuild!
Went to buy some rebuild cleaner and they wanted $70.00 What I says! Will paint thinners and gasoline work? What else is there?
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
11-02-2004, 02:57 PM | #2 |
Designated A-hole!
That's insane! Carb cleaner is about $3 a can around here the last time I bought some.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-02-2004, 02:58 PM | #3 |
Its Magically Delicious
79 cents at wally world
71 C10 LWB 350sbc -TH350 12 bolt 3.42 Posi Of all my favorite things to do, The utmost is to have a brew. My love grows for my foamy friend, with each thirst-quenching elbow bend. Beer so frosty, smooth, and cold it's paradise pure liquid gold. Yes beer means many things to me that's all for now cus I gotta pee. |
11-02-2004, 03:08 PM | #4 |
I think he is talking about like a 5 gallon bucket of the cleaner or maybe more not a spray can.
11-02-2004, 04:25 PM | #5 |
Watch out for your cornhole !
Buy a 1 gallon can of Berryman's carb dip at the parts store. It will come in a metal 1 gallon can like a paint can. It will also have a wire dip basket inside the can to put the parts in while they soak in the can.
Usually about 18-22 dollars for the gallon, which will last a long time (plenty of carb overhauls) if you don't trash it out with heavy grease.
11-02-2004, 04:33 PM | #6 |
hmm...
we use paint thinner (turpentine) on all our carb rebuilds for the soak. Let that sucker sit overnight in the bath, pull it out, wash it out with water, then take pressurized air and blow it dry, making sure to get every passage.
For restoration projects, we shoot the main body with clear coat, but just on the outside and we mask all the gasket surfaces and such. Makes it look brand new.
1983 Oldsmobile Delta 88 1967 Chevy C-10 stripper www.fcrperformance.com - wanna go...faster? talk to FCR. |
11-02-2004, 05:23 PM | #7 | |
Resident Curmudgeon
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-03-2004, 12:51 AM | #8 |
BIG bucket with dipper dipper~
Other walmarts and **** tire have thinners!
11-03-2004, 09:17 AM | #9 |
1969 Custom 30 wrecker
Go to Advance auto or Autozone. They sell a 1 gallon metal can of carb solvent that even has a metal parts strainer in it for about $10. I think it's Gunk brand. I've been using this brand with good results. When the solvent gets dirty, just buy another can. I have 2 now and the old can I use to clean greasy parts in so I'm still getting my moneys worth out of the old one!
Spray can carb cleaner is .88 cents at Walmart! I use that stuff on everything for that price.
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
11-03-2004, 11:36 AM | #10 |
It's a catastrophic success.
If the real stuff is to pricey, I use (Laquer thinner)and a spray can of carb cleaner to to get in the tight spots and pin holes, works great but is a little rough on the hands, avoid putting rubber parts that you plan on reusing in the bucket.
