11-02-2004, 07:30 PM | #1 |
Toolpimp here's the info
Heres a pic of the hubs we talked about.. I never told you about the warn hubs that will also fit. They are 19 spline and thats the correct axle in the pic also. Also shown is the Ford hub I told you that would fit also.
I opened up a spicer hub to show you the parts all in there. I know the stuffs hard find.... and I know you need it. Let me know if you can't get anything.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. |
11-02-2004, 07:33 PM | #2 |
1970 and 1971 vin decoding.
Here's how you decode a GMC vin from 70 and 71....so its a 70 GMC vin you showed me , not a 71 as someone else told you.
Your front drums are a 1 year only item...harder to find than the hubs in my opinion.
11-03-2004, 12:59 AM | #3 |
Remembered about the older spicer hubs also.. they will work also.
typical 67-69 stuff. It should bolt on to a 70-72 also.
11-04-2004, 12:50 AM | #4 |
Here is a pic of Warn hubs on a 69 3/4 ton.
I can't remember if it needs the about 3 inch thick spacer like the spicers or not... I'll go look at it tomorrow.
