Ordered my headers today
Well, I decieded to go with these headers I found on ebay http://cgi.ebay.com/ws/eBayISAPI.dll...e=STRK:MEWN:IT
The price was right..... I just need to make my mind up on the Flowmaster or the Borla mufflers now? ![]() ![]() ![]() Hopefully I'll have made my mind up here in a week and a half, that's when I get it all done. Anybody have any sound clips of the Borla mufflers?
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 |
Got Light Emitting Diode?
hope those headers fit for ya. mine sweep way out of the way of the motor mount
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
They better!!! A buddy of mine used the same ones on his '82 Chevy.
they going on your 71???
Watch out for your cornhole !
![]() Join Date: Jun 2003
Just because they clear the engine mounts on an 82, they still might not clear on a 71.
The link doesn't work for me, but if they're blockhuggers, they will probably hit the engine mount stands.
#6 | |
![]() Join Date: Apr 2004
![]() Quote:
1968 Chevy 4x4 307 4 speed |
Those look just like the Summit brand headers that are actually re boxed headers by Dynomax. Summit sells them for $188 and change + the ride. I have a set...very nice!
Alex 1971 Lil' Red 350 SBC 700R4 |
Registered Cruiser
You might have a clearance problem with your clutch linkage. Long tube headers sound great with 2.5" pipe and turbo muffs.
I intend to live forever. So far, so good. |
go for the borla mufflers! i think youll like them over the flowmasters. in my opinion flowmasters are played out.
70 longbed 496/th400/Ford 9" |
Professional Grade
I'd say the Borlas too! Sound very throaty. I personally am running a set of Flo Pros and have no complaints until you get to be crusing at 70 mph, then they drone enough to get on your nerves. I'm told an x-pipe would fix that problem though
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Borlas are so sexy, and it seems like no one knows about them. I hardly hear them on older trucks, but a good number of late model Chevys have them and I can point them out in a instant. When I get new muffs I'm gettin Borlas.
Brian 72 C10 longbed 350/th400 Let the world change you and you will change the world. |
What was I thinking??
I thought they looked liked Flow Tech headers...I could swear that was the same pic I saw on their web site.....
Cethern
72 K5 that needs lots of parts.. 71 GMC 3/4 4x4 That doesn't need much which is a good thing I don't think I could aford another money pit... |
#13 |
If they're the same ones as in the pic then they are the summit part No SUM-G9006-9 headers that Tx Firefighter recommended in a previous thread, and the price is about 200 bucks and free shipping.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#14 | |
Yes, they are going to go on my '71. I am also leaning more towards the Borla mufflers with the X-pipe.
I wish I looked around a bit more if they could be had for under $200.... I ended up paying $224 shipped to the door. Well next time I'm looking for something I'll post it first and find all the good deals. Quote:
Thanks for the complements everyone, Steven
#15 |
They fit nicely no problems at all....
#16 |
good to hear. got pics???
#17 |
They will be in the works today. I'll post them up tonight.
#18 |
I snapped a few quick pics when I got home this evening, and it got dark quick. I'll try to get some better ones with the clutch linkage in it so you can see the clearance.
2002 Silverado 2500HD LB7 CCSB LT EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's 2004 Tahoe LT 2006 Silverado Z71 LS 1971 Chevy C10 Last edited by 1978steven; 11-15-2004 at 10:09 PM. |
#19 |
As you can see I have alot of work under the hood of this thing, but I'll have her a cleaned up and look'n good......
#20 |
I never posted it on this thread but the headers are the Flow Tech by Holley....
#21 |
Registered Cruiser
Those headers look great Steve.
#22 |
in the first pic plug wire #2 looks like it is sitting on the header. is that orange rubber going to stant that hot of a temp???
#23 |
I doubt the rubber boots on the plug wires would withstand the temps of the headers, but there is a decent gap between the boot and the header. I had to change a few of the plug ends to the 90 degree bends; if I have to change a few more I will. We will see what happens.
#24 |
Professional Grade
Those are good looking headers!
I think I'll get a set of them when I get a new set later on (current steel ones are fine for now, but will rot away in a real hurry)
#25 |
Your UncleBen
![]() Join Date: Dec 2002
You ever thought about the mufflers done by Magnaflow. They are some sweet sounding mufflers if you set them up right. Just depends on the sound you are going for. On my 71 I am going with some Hooker Super Comps and 3 " 3 chamber Flowmasters. Cant beat the sound!! Mean!!!!!!
lata CHRIS
68 C10 shortbed -- Street/Strip ![]() |
