11-03-2004, 04:02 PM | #1 |
computer illiterate
fuel pump?
what psi does a stock fuel pump on a 1977 454 put out?
72 2wd blazer 72 swb 4x4 |
11-03-2004, 05:00 PM | #2 |
Chevy Freak
fuel pump
I was thinking somewhere in the 5 psi range.
69 GMC SWB, 350 70 Chevy LWB, 350 55 chevy gasser, 461 73 Camaro, 496 67 RS Camaro, 406 64 Chevelle, 588 71 Nova, 565 67 Camaro, 461 |
11-03-2004, 05:54 PM | #3 |
Fabricate till you "puke"
Yup, probably in the 5-6 psi range.... crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
11-04-2004, 02:57 PM | #4 |
computer illiterate
so it should be good with an edelbrock carb without a regulator?
11-04-2004, 03:09 PM | #5 |
Chevy Freak
fuel pump
Yep. Stock pump will be fine without a regulator.
