Old 11-03-2004, 06:52 PM   #1
skokie
skokie's Avatar
Converting from a gas pedal rod to a cable.
What would you need to do swap from a throttle rod to a cable? Has anyone done this?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 11-03-2004, 07:38 PM   #2
68w/sbc406
Got Light Emitting Diode?
68w/sbc406's Avatar
i was thinking about doing it but then i made a the throtle linkage longer (L6 to V8) i have the pedal and cable though if you cant find one
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags
'02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's(the family car)
1993 Cherokee work ride/weekend wheeler
68w/sbc406 is offline   Reply With Quote
Old 11-03-2004, 07:39 PM   #3
skokie
skokie's Avatar
Thanks. What else would you need to do to convert it?
68 build thread
Old 11-03-2004, 07:42 PM   #4
68w/sbc406
68w/sbc406's Avatar
i am pretty sure its just a pedal that bolts to the fire wall in the same spot as you existing pedal, then a cable that hooks to the top of pedal that you would need to cut a hole in the fire wall, and a bracket on the intake............i think
Old 11-03-2004, 07:59 PM   #5
neonlarry
neonlarry's Avatar
Check out this thread:
http://67-72chevytrucks.com/vboard/s...hreadid=100644
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
