Old 11-04-2004, 06:29 PM   #1
TIMSPEED
TIMSPEED's Avatar
"Bolt-On" Sir Michaels Roll Pan: Brackets??
I'm about to order one of the "Bolt-On" Sir Michaels Roll Pan's...my question is, how does it Bolt-On? Does it have it's own brackets, and I just bolt it to the frame, or does it use stock rear bumper brackets, that I'll have to go get from Pick & Pull?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 11-04-2004, 07:01 PM   #2
Jonboy
Slots go on anything!
It will have it's own brackets. It is held on at the top by about 6 sheetmetal screws into the rear sill of the bed, and 2 tabs on each side that are held on with sheetmetal screws also. If you are having the bodywork done, maybe they could weld the sides on and mold it in for you.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-04-2004, 08:42 PM   #3
TIMSPEED
TIMSPEED's Avatar
From the way you describe it, it sounds more like a weld-on. I thought the "Bolt-On" ones, were entirely bolt-on, no need to drill holes in the bed to attach it.
See Them Here
Old 11-04-2004, 09:42 PM   #4
BaggedC10
Under construction!
BaggedC10's Avatar
To install a bolt you must have a hole.
I had a weld-on SM roll pan on my 87' and it was a nice piece.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 11-04-2004, 09:44 PM   #5
leastbay
mine was bolt on but i welded it its pretty much the same thing except the bolt on they put holes along the top i highly reccomend getting it welded im sure you could get it done pretty cheap if yougrind down the welds yourself
leastbay is offline   Reply With Quote
Old 11-04-2004, 09:52 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
All the rollpans are the same, they can either be bolted on or welded, there are NO brackets required or included. I had mine welded on for a smooth finish.
I recommend http://www.customclassic.com/ they are a preferred vendor :p
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-04-2004, 10:21 PM   #7
swervin ervin
You get what you pay for
swervin ervin's Avatar
I have a bolt on fiberglass and it came with brackets and screws. It screws to the rear sill of the bed and a bracket on each side where it meets the bed side. It also came with a center bracket/brace that bolted on behind the tag. When/if I ever get my truck painted, I will swap it for a steel weld on roll pan.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-04-2004, 10:29 PM   #8
TIMSPEED
TIMSPEED's Avatar
WOW! Thanks for posting that! $140 shipped! WORKS FOR ME!
See Them Here
Old 11-05-2004, 07:52 AM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
I think if you mention your a fullsizechevy member you get an additional 10% off but Im not sure....ask when you call :p
1991 GMC Jimmy 4x4
