11-04-2004, 08:53 PM | #1 |
Shortbox wanna-be.
Driveshaft differences between a TH350 & TH400 ????
I bought a rolling shortbox frame which included a 12 bolt rear and the 2 piece drive shaft. I know the truck originally had a small block in it, so I assume it had a TH350 trans. (1970)
I am installing an original BB402 with the matching TH400 into this frame. Will the 2 piece drive shaft still work? Or were they different between the 2 ? thanks
1970 Chevy C20 Custom Camper 402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton) '71 Camaro SS 402/T400 resto '97 Z28 (11.41@127MPH) |
11-04-2004, 08:59 PM | #2 |
Yes--you will have to change the front yoke to 400 style.
56 Chevy Bel-Air 2dr. HT (purchased new) 71 Chevy Cheyenne SWB PU (502HO) 65 GMC short bed step--work in progress and my gofer |
11-04-2004, 09:09 PM | #3 |
jhow66 is correct, the 400 is a fine spline with more teeth which makes it more heavy duty
than the 350 coarse spline.
1968 Chevy 4x4 307 4 speed |
11-04-2004, 09:24 PM | #4 |
plus depending on the tailshaft length you might have to get the driveshaft cut down
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-04-2004, 09:48 PM | #5 | |
Shortbox wanna-be.
Ok, I can do that. I have the original yoke still on the driveshaft on the 3/4 ton frame. There is no way for me to measure tailshaft length as I don't have the TH350 that was in the shortbox frame. Does anyone know the difference in lengths?
11-04-2004, 10:16 PM | #6 |
Transmission dimensions: http://tciauto.com/tech_info/trans_dims.htm
11-04-2004, 10:27 PM | #7 |
Shortbox wanna-be.
Can anyone tell me what the TH350 tail shaft length was on a '70 C-10 with a small block?
11-04-2004, 10:46 PM | #8 |
Ditch the 2 piece and put a single driveline in,you want regreat it!
Things happen for a reason! |
11-04-2004, 10:51 PM | #9 | |
Shortbox wanna-be.
Actually that is my overall plan. This is to just get me by for now. I just want to get the truck mobile first. I can change out the driveshaft later on. I am trying to only spend my cash on stuff I NEED right now, with all the goodies later on. |
11-04-2004, 11:29 PM | #10 | |
Watch out for your cornhole !
