Old 11-05-2004, 12:42 AM   #1
REPO1
Shortbox wanna-be.
REPO1's Avatar
Question What is the smallest air tank I can get away with?
I don't plan on hopping or anything with my truck, but would like air it down when parked, then lift it to ride height when I want to go somewhere. I already bought Slam Specialties bags that have 1/2 ports, but I think I am only going to run 3/8 lines and valves to save a bit of cash. I was hoping to hide the tank under the truck somewhere, and I will be mounting the fuel tank under the bed.
What is recommended?
1970 Chevy C20 Custom Camper
402BB Turbo 400 trans. (Slowly becoming a '70 shortbox 1/2 ton)
'71 Camaro SS 402/T400 resto
'97 Z28 (11.41@127MPH)
REPO1 is offline   Reply With Quote
Old 11-05-2004, 04:03 AM   #2
fastbagged68
fastbagged68's Avatar
6 gallons of Air, to go from 3/8 to 1/2 inch is not much more. maybe a few bucks.
fastbagged68 is offline   Reply With Quote
Old 11-06-2004, 07:05 PM   #3
XXL
Seņor Member
XXL's Avatar
3 gallons works fine, but you'll cycle the compressor EVERY time you raise it. You've got room under your truck for plenty of air... I'd recommend 5-6 gallons as well, that way you don't tax the compressors (because you ARE gonna play with the bags every once in a while).
XXL is offline   Reply With Quote
Old 11-06-2004, 08:12 PM   #4
Shev
Head Peon
Shev's Avatar
I would imagine it would be pretty easy to fit a couple of 5 gallon "slim" tank under there...
[IMG]http://www.*****************/products/slimtank.jpg[/IMG]
5 Gallon Slim Tank
Or I know the S-10 guys can fit an 8 gallon between the framerails where the spare tire used to be...
8 Gallon Tank
'72 Suburban, factory tilt, tach, front & rear AC, front & rear disc brakes, 383/700-R4
Shev is offline   Reply With Quote
Old 11-06-2004, 08:29 PM   #5
REPO1
Shortbox wanna-be.
REPO1's Avatar
Keep in mind that I am putting a fuel tank under the rear of the bed, so will there still be lots of room?
Its hard for me to picture right now, as I have the entire truck ripped apart. Maybe once I get the frame together and the cab back on I may have a better idea, but until then I am relying on you guys.
Old 11-07-2004, 11:50 AM   #6
SCOTI
SCOTI's Avatar
More than likely, your fuel tank will be @ the very rear of the truck so a couple of small tanks on each side @ the front of the bed will work fine. 2 x 3gal tanks will work but there's room for larger if you want.
I use 1 x 3gal tank for the rear bags on my beater68. The only time I mess w/the system is when I'm getting ready to tow something.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-08-2004, 05:00 PM   #7
XXL
Seņor Member
XXL's Avatar
For trucks with trailing arm rear, there is LOTS of room on either side of the driveshaft. I've got a 3 gallon tank, valves, and compressor on either side of the driveshaft, and at full drop they are well above the trailing arms. There's easily room for 5 gallon tanks per side.
Old 11-08-2004, 05:34 PM   #8
Slammed67
Progress = 0%
Slammed67's Avatar
.....unless your exhaust pipes run through this area. If you have a longbed, you should have plenty of room in front of the rear wheels, under the bed.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 11-09-2004, 01:06 AM   #9
REPO1
Shortbox wanna-be.
REPO1's Avatar
I too will be running my exhaust throught the crossmember. And the truck is a shortbed. Hmmmmm, this could be a tight fit.
