![]() Join Date: Jun 2003
I'm sure many of you guys know the answer to this: Can the power steering box and column from a 2wd C-20 be used on a 4x4 K-20 frame??
Thanks for your guidance, 72longbed ![]() ![]() ![]() |
no
user # 2756
![]() Join Date: Jun 2001
The column yes but not the gear box unless you do a cross over steering set up. But then you'd need to have the pass side steering knuckle modified, and a new drag link made. Truck would also have to be lifted.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
SKINNY TIRES RULE!
Lift should be over 6" for cross-over too.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
user # 2756
Also forgot would need a diferent pitman arm.
OK,
so what power steering box is in a 'factory' K-20 with power steering? And what if the 4x4 is manual steering and you want to convert it to power? Thanks again, 72longbed |
Next!
72 Longbed, aren't you the one who got the trailing arm from me? I Have one of those PS boxes, good for a core at least.
86 K30 CUCV M1028A1 86 K30 CUCV M1028a2 dually 86 K30 C&C 6.2 4:56s, 4M, 11,000 gvw, ex fire truck, now lowboy dump More square bodies and CUCVs than I care to admit to 2020 Silverado K3500HD Work truck |
I just swapped the pitman arm on mine.
Longhorn4x4,
are the power steering boxes the same, (2wd vs. 4wd), with just a different pitman arm? Thanks, 72longbed |
Got Light Emitting Diode?
not a pro, but i think 4x4s are on the inside of the frame, and 2wd are on the outside. but when i put ps on my truck it had to be 71-87 2wd 1/2 ton period
1968 1/2 ton 2wd lwb 6 lug disc and bags up front. Next c notch and rear bags '02 Chevy Silverado LT ext cab short bed 2WD 5/7 drop on 22's ![]() 1993 Cherokee work ride/weekend wheeler |
Recovering 67-72 Addict
![]() Join Date: Oct 2000
It is a different box and a different pitman arm. You will have to find a donor 4x4, buy one off this board. or purchase a new one. I put a box from AGR on mine.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
Next!
69-72 K-5,K10,K20 ps boxes will all interchange, and they are different than their 2wd counterpart.
#13 |
user # 2756
4x4 gear boxes are on the outside of the frame also.
#14 |
Thanks GM72K10 and everybody else, I finally understand what I need now. I've been kicking around the idea of finding a 71 or 72 4x4 rolling chassis and hanging all of my sheet metal and drive train on it. I want to be prepared if I can only find a 'manual steering' chassis as a donor. I'll be selling my 2wd rolling chassis on this board or E-Bay if anybody is interested. Now that I've replaced all the wear parts from front to back it's time to sell it, right...?
![]() ![]() ![]() Thanks again, 72longbed (anybody know of any good 4x4 rolling chassis around PA, prefer 3/4 ton?) Let me know. |
