Old 11-05-2004, 01:14 PM   #1
jbw0127
Rear Discs
To those who have converted to rear discs.
Did you stay with your original master and just install an adjustable prop. valve. (my master is disc/drum)
Recently I was told that I needed to get a disc/disc master and maybe a disc/disc proportioning valve and also install 2psi residual valves for the front and back (thought these are mainly for systems with the master lower than the calipers).
I just wanna get it right the first time and not dick with it later!
72 swb Cheyenne
"nut & bolt" frame off (in process)
Blown 383
jbw0127 is offline   Reply With Quote
Old 11-06-2004, 09:17 PM   #2
jbw0127
Ttt
ttt
72 swb Cheyenne
Blown 383
Old 11-07-2004, 01:55 AM   #3
roj2323
i have simular question so i will add it here instead of a new thread.
for those who have converted there rear ends to disk where did you get your kit and or parts?
thanks,
ondrew
roj2323 is offline   Reply With Quote
Old 11-07-2004, 02:22 AM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Check out this thread.
CLICKY
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 11-07-2004, 04:39 AM   #5
GMCPaul
Thumbs up
Your not optimizing the disc/disc setup unless you use a disc/disc master cylinder & disc/disc prop valve or adjustable prop valve. The brakes will work as good or better going disc/disc over disc/drum while keeping a disc/drum master & prop valve but they will not work as well as with the disc/disc master & prop valve. The residual pressure valves however are not needed, they only need to be used when the master cylinder is located below the calipers such as under the floor on early trucks and they only act as a check valve to prevent the fluid from overflowing the master cylinder.
The best route in our opinion is a disc/disc master cylinder with a adjustable valve on rear line and nothing on front line so it receives full pressure to the front brakes, then dial down the rear brake pressure until you no longer lock up and braking brings you to a smooth stop. If your rear brake pressure it set slightly high on rear instead of stopping smooothly the brakes feel ultra touchy and want to grab suddenly.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 11-07-2004, 10:44 AM   #6
gmc67swb
gmc67swb's Avatar
GMC Paul, do you have a complete kit to do this swap front and back? Mine is a '67 GMC with the Dana 44 out back originally equipped with drum/drum and 6 lugs. Would like to go to 5 lugs and lower the truck in the process. Sorry, not trying to hyjack this thread.
GM 330HP/350, Magnuson 122HH, Tremec TKO 5spd
gmc67swb is offline   Reply With Quote
Old 11-07-2004, 01:41 PM   #7
roj2323
interesting articals.
Old 11-09-2004, 12:15 PM   #8
jbw0127
What master?
GMCPaul or whoever......
What master cylinder do you recommend and will bolt up to the stock power booster?
72 swb Cheyenne
Blown 383
Old 11-09-2004, 12:47 PM   #9
raggedjim
raggedjim's Avatar
68-mid seventies corvette worked for me... I used a disc/disc combo valve from CPP, works like crazy...
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
