Old 11-05-2004, 04:56 PM   #1
CPNE
Resident Curmudgeon
CPNE's Avatar
Quick ? about I6's and HEI wiring
I have an HEI from a 77 Nova that I'm installing on my 250 six. It has the external coil (not integrated into cap). My question is how do I wire it as it does not have a spade marked battery on the coil as on the V8 version. In short:
Which spade terminal on the coil (as you face the block from the RH side) does the 12v lead go to? Is it the rear left spade or rear right spade? The rear right has a plastic tab on it that aligns the harness from the HEI pick up, so the standard connector won't slde down on it. Also, does this need to be grounded in any special way?
Pics
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 11-05-2004, 07:10 PM   #2
vtblazer
vtblazer's Avatar
Your using an HEI?! So it must have been stock then?
vtblazer is offline   Reply With Quote
Old 11-05-2004, 08:07 PM   #3
MOTHERTRUCKERS
Jeff call me tomorrow toll free if nobody answers on the board, I have divorced coils on a couple of 292's at the shop.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 11-07-2004, 10:58 AM   #4
CPNE
Resident Curmudgeon
CPNE's Avatar
Thanks Ed, I got it wired and it runs great!
VTBlazer, touche
Here is a pic of the engine. It has PS and will have the correct air cleaner assembly for the booster clearance too
Old 11-07-2004, 11:05 AM   #5
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Mechanic's hand soap like Goop or Gojo will clean those plug wires to to look like new.
Old 11-07-2004, 11:08 AM   #6
CPNE
Resident Curmudgeon
CPNE's Avatar
I was happy it ran at this point, but thanks for the tip. There's a lot left to do
