Old 11-06-2004, 12:39 PM   #1
PHOENIX
Second Alt and Batt
I have thought about running a second battery and alternator.
The second battery and alt would be for accessories only.
When I have the lights on, sterio pumpin' and electric fan going there is a drain on my power system. The lights dim with the bass. I plan on adding some lights and maybe a few other electrical components later and think the more power the better. Plus with another battery, you can always use it if the first one dies. I need to get a better alternator, but I am interested in a second setup like I have as another option (probably cost more).
Anyway my question is does anyone make a alternator bracket (stock like) for the drivers side of the engine? One like stock, just a mirror image?
If so let me know where to find it.
Also I know I could get a battery and drivers side battery tray no problem.
So the bracket is the only concern as far as materials.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION *
PHOENIX is offline   Reply With Quote
Old 11-06-2004, 06:26 PM   #2
1974ChevyC10
Overworked and Underlaid
1974ChevyC10's Avatar
i dont know about the 2nd alternator but my uncle used to have a 76 GMC that he added an 2nd battery in by using a battery junction.he had all of his accessories wired to the 2nd battery and the main battery ran the vehicle electrics.he got it at some 4x4 shop.
I'd rather push a Chevy than drive a Ford
The Beast-1978 C10 LWB
Red-1978 C10 LWB
(Uncle Mike)Michael Henry Millett 11/5/1957 to 03/08/2012
Gone but will never be forgotten-RIP
(Uncle Chuck)Charles Manning Gulbronsen Sr 1956-2012
Taken from us to soon but you will live on in our hearts-RIP
1974ChevyC10 is offline   Reply With Quote
Old 11-06-2004, 07:52 PM   #3
Prerunner1982
Prerunner1982's Avatar
get a big alt and you wont need 2. The one will charge both, there are a few companies that sell battery isolator kits with a switch to run both, one, or neither.
Prerunner1982 is offline   Reply With Quote
Old 11-07-2004, 07:16 AM   #4
Mike76251
If you put on one of those isolater kits (a three position switch)......DO NOT, whatever you do, switch it to the off position when the engine is running.
It will fry the diodes in the alternator in one second flat.
As for a bracket for a driver's side alternator ;
Jeg's page 62-X lists March brackets for either side.
Mike76251 is offline   Reply With Quote
Old 11-07-2004, 12:10 PM   #5
Destructo
I'd put one big alternator on it and run two batteries with an isolator.
1985 Scottsdale Shortbed 4x4
Stout 350 with some "upgrades"-700r4-33x12.5" Mud Tires, Warn 8274-50 winch.
2005 Chevrolet Colorado Regular Cab 2wd 4-banger, 5 speed, Street Pack with 3.73 axle.
Destructo is offline   Reply With Quote
Old 11-07-2004, 03:48 PM   #6
rolson1039
you can actually get an isolator at any marine supply store
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 11-07-2004, 04:10 PM   #7
Russell
Professional Grade
Russell's Avatar
I would also suggest running the dual battery setup too, and just get one big alternator instead of two smaller ones.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 11-07-2004, 04:27 PM   #8
82BlackBeast
what type of battery are you running and what size alternator?
Matt
'82 Chevy SWB
82BlackBeast is offline   Reply With Quote
Old 11-08-2004, 01:25 AM   #9
Tom
driving is in my blood
Tom's Avatar
I bet your running the stock 63 amp alt, try using a late 80's [
i used a 89 2500 4x4] suburban alt thats 78 amps. Might be all you need. I run my sterio hard and my battery is going on 3yrs in this heat.
Old 11-08-2004, 01:28 AM   #10
Crank
Crank's Avatar
Isnt it true the battery is only used for starting the vehicle? Then the alternator runs the accessories. So if that's the case, you only need one battery for startup, and 2 alternators for the accessories, or one high amp alt. or you could get a power capacitor(sp?) to hold power for the low notes of bass...
Brandon
Crank is offline   Reply With Quote
Old 11-08-2004, 10:59 AM   #11
TooMany2count
Who's in CHARGE??????????
TooMany2count's Avatar
get a larger output ALT. (some of the later model cars & truck have 100amp alt) and put relays on your extra lights, electric fans.. http://www.madelectrical.com/electrical-tech.shtml <~~~read through this page...joe
Send a card to a soldier in Iraq
My Music PlayList
Large Marge
Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE
TooMany2count is offline   Reply With Quote
Old 11-08-2004, 12:18 PM   #12
PHOENIX
Im running a 94 amp alt and a Optima Red Top Battery.
Power is only an issue at idle. I need an alt capable of putting out a lot of amps at idle speed.
Old 11-08-2004, 01:46 PM   #13
82BlackBeast
ok so you have a good battery and alternator, are you running maybe an underdrive pulley on the alternator? I only have probs at idle as well, I have almost the exact same setup and mine started when I swapped to an underdrive pulley.
Matt
'82 Chevy SWB
