Old 11-06-2004, 02:59 PM   #1
ocbaud
Garage Queen Material
best way to remove the rear?
okay, i got my truck in the garage, bed on, everything bolted up.
what is gonna be the easiest way to take the rearend out? should i start unbolting the U bolts first and then take the leaf spring off?
ocbaud is offline   Reply With Quote
Old 11-06-2004, 03:09 PM   #2
badone07
Project 2 Resume
badone07's Avatar
Not sure if you plan on swapping springs, the rear or both. The 4 u-bolts might be harder to remove, than removing rear with springs attached. Especially if they've been there from the factory. I would just disconnect rubber brake hose. Unbolt the shocks and driveshaft. Take the bolts out of the spring eyelets. Then do whatever you need to do with the whole unit out of the truck.
If just replacing the springs, I would just do one spring at a time. Only unbolting the shock for that particular side at a time. Also sometimes easier just to cut ubolts and replace with new ones.
John
1984 C30 Chevy Crew Cab Dually
1998 Jeep Cherokee 4x4
2004 Chevy Trailblazer 4x4 (wife's)
1970 Mustang FB fully tubed (getting 521 BBF & powerglide)
1978 Nova 2dr (going BBCaddy & S.P. th400)
1984 Monte SS (circle track car)
badone07 is offline   Reply With Quote
Old 11-06-2004, 03:18 PM   #3
ocbaud
i'm pulling the rear so that i can have it rebuilt.
the rear has a flip kit on it too, so thats why it wouldnt be easier to just drop the rear.
Old 11-06-2004, 03:23 PM   #4
swervin ervin
You get what you pay for
swervin ervin's Avatar
You've already had it out to flip it. Why then are you asking how to do it now??
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 11-06-2004, 03:26 PM   #5
ocbaud
because, it took us half a day to get the rearend done, i was just wondering if there was a faster way to do it.
Old 11-06-2004, 04:29 PM   #6
ocbaud
now i'm having trouble removing the rear brake line that goes from the frame, to the axle.
Old 11-06-2004, 05:37 PM   #7
low 84
low 84's Avatar
why are you taking it out to have it rebuilt? they can rebuild it while its in the truck perfectly fine.
i would do the ubolts and shackles last. unbolt the brakelines, shocks and driveshaft. have fun with the parking brake cables, i hope you've worked on drum brakes before. then do the u bolts which are probly seized up also. then just unbolt the shackles on the rear and let the back of the springs drop down, no reason to unbolt the front of the springs. use a bunch a penetrating lube and go easy on the break fitting, they strip easy
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 11-06-2004, 06:39 PM   #8
ocbaud
im having the rear rebuilt for next to nothing or nothing at all.
my dads friend knows how to do it all. so its just easier for me to take the axle to his shop, and that way, i can clean it up and paint it some and gives me something to do for a couple days!
and no, i have no clue how to take the ebrake cables off
Old 11-06-2004, 08:16 PM   #9
badone07
Project 2 Resume
badone07's Avatar
You could have someone else do it. J/K.
Remove c-clips. Pull axles. Undo brake lines to the wheel cylinders and cap them. Remove backing plates and leave them on the floor, with your truck. OR Leave brake lines attached to wheel cylinders and use bungies or wire to suspend the backing plates temporarily.
John
Old 11-06-2004, 09:11 PM   #10
low 84
low 84's Avatar
huh? why would he pull the axles to remove the rear end?
'05 1500 Crew Cab
RIP
Old 11-06-2004, 09:14 PM   #11
ocbaud
anyway, its out now.
all the metal shavings are in the casing haha, and i cant pull the pinion shaft out, even with the retaining bolt taken out. its messed up that bad
my next project is changing the speedo gears
Old 11-06-2004, 09:52 PM   #12
swervin ervin
I think John meant to pull the axles so he could take the backing plates off with the shoes and brake cables attached. Hey, works for me.
Old 11-07-2004, 12:23 AM   #13
badone07
Project 2 Resume
badone07's Avatar
That's exactly what I meant. Just another way to skin a cat, so to speak. Sometimes different circumstances require a different plan. We are only trying to help out without actually seeing how his truck is setup. In addition to not knowing what tools he has available and/or knowing his abilities.
John
Old 11-07-2004, 01:24 AM   #14
ocbaud
my abilities include pulling the rearend out, without unbolting 1 single leaf spring and keeping all the brake backing plates on
now, whats a good way to pretty this rearend up? with out powder coating and sand blasting it?
Old 11-07-2004, 10:21 AM   #15
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
I went from this (notice tubes) http://www.captkaoscustoms.com/images/Eatonsetup.jpg to this http://www.captkaoscustoms.com/images/POR15diff1.jpg
I sprayed it down with Easy-Off oven cleaner, then sprayed it off with water. What didn't come of the first round was hit again with Easy_Off, scraping the thick stuff prior. Ran over the whole thing with a wire brush. Loaded up the spray gun with Gloss POR15 and there you are.
I cleaned it off first, setup the rearend and then painted it.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 11-07-2004, 01:38 PM   #16
ocbaud
easy off.... i guess i'll give that a try
Old 11-07-2004, 02:19 PM   #17
swervin ervin
Don't breath the fumes or you'll be dumber than you already are.
Old 11-07-2004, 02:26 PM   #18
ocbaud
is this stuff flamible?
oh yeah, looking at the axle, on the drivers side , where the axle shaft goes in, it looks like its been leaking a little bit too.
Old 11-07-2004, 04:05 PM   #19
rolson1039
when i need to pull a rear i tend to just bust off the U bolts on the leaf springs makes life a little easier than pulling the springs too. If i remember correctly y ou have a lowered truck i dont know if there will be clearance issues with yours but mine ( i keep mine stock height or higher) i can get in there with a breaker bar and long pipe on it for leverage and can usually bust em off easy. MY one reccommendation would be to use PB BLaster on your U Bolts anmd if ya can use the blaster on it a day or so before then do it just before you loosen the bolts up youll find it works alot easier
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 11-07-2004, 05:15 PM   #20
ocbaud
i used pb blaster about 5 minutes before i did it, then i used about a 16" closed ended wrench to undo them. had to use my legs to break the loose on a couple of them the bad thing about mine is that they are extra long ublots because of the flip kit, and i havent gotten them cut down yet.
Old 11-07-2004, 06:12 PM   #21
badone07
Project 2 Resume
badone07's Avatar
http://207.44.196.117/vboard/showthread.php3?t=126481
John
Old 11-07-2004, 06:18 PM   #22
ocbaud
i know, it was my dads idea
i was planning on taking them off.
Old 11-07-2004, 06:25 PM   #23
badone07
Project 2 Resume
badone07's Avatar
Just busting on ya. Had a long day today walking around a junkyard looking for a suitable 429 or 460 BBF core. Then I saw the bushing post and the rest of rear post. Just had to laugh and point that out. Without seeing it in person, guess the 4 leaf spring bolts would've been easier. At least you wouldn't have to get down on the ground again. Chalk that one up to experience. Hey, at least you got it and are making progress.
John
Old 11-08-2004, 05:45 PM   #24
Captkaos
Captkaos's Avatar
Yeah, you really don't want to breath it, but I use it to clean anything greasy/oily. Works like a charm.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 11-09-2004, 05:32 PM   #25
KShortell
KShortell's Avatar
Use gloves, too! The stuff removes your fingerprints for a while...
EZ-Off works wonders for changing the name on a boat.
Semper Paratus
KShortell is offline   Reply With Quote
