11-06-2004, 06:13 PM | #1 |
prevent engine rotation
I'm trying to torque the damper into place... I've only got 1/16" left to go but the crank is spinning now (at about 55 lb/ft). I put in the spark plugs which helped a bit but I e\need to keep the crank from turning - what's the technique??
11-06-2004, 06:19 PM | #2 |
I have used a screwdriver wedged inbetween the teeth of the flexplate and the block.
Never had any problems that way, although it might not be an acceptable practice. Dan |
11-06-2004, 06:33 PM | #3 |
its all about the +6 inches
Shove a looong flat head inbetween the torque converter and fle plate. Let it turn untill it smacks the bellhousing...it won't move any more.
Just remember to remove it before starting engine. |
11-06-2004, 06:59 PM | #4 |
MAC & SNAP-ON BOTH MAKE TOOLS TO TURN FLYWHEELS & FLEXPLATES. THEY WONT DAMAGE THE TEETH OR BEND THE FLEXPLATES. THE TOP ONE IS A MAC & THE BOTTOM ONE IS A SNAP-ON . JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
11-06-2004, 09:56 PM | #5 |
In the end I just put a C-clamp on the flexplate and that did the trick.
11-06-2004, 10:35 PM | #6 |
Still drivin' a Rat Rod
Large vise grips will do the job nicely as well.Clamp them on the flexplate,and torque away.
Rusty Member #13872 Instead of saying.....you are a discomfort in the back of my front.....one should be able to say...... you are a pain in the *a$#* 71 GMC LWB 49 Chevy 85 Chevy G20 Check out my website |
11-07-2004, 05:55 AM | #7 |
Who needs a torque wrench??? They are just play toys for girls! Get your impact wrench & tighten until you can't tighten any further. The bolt heads will pop right off when they are properly torqued.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
