Old 11-06-2004, 07:44 PM   #1
77gmcjoe
What do we get for $10?
77gmcjoe's Avatar
Shocking question!
This might seem kinda crazy, but what is the usual direction to put shocks?
I installed mine with the boots to the bottom, but since then I've seen several with the boots on top. Just wondering how everyone else has theirs?
Thanks guys,
Joe
1977 GMC K25 400/400/205
1989 Chevy Suburban R1500 350/700R4 (work beater)
1994 Chevy K3500 dually 454/4L80
1996 Corvette LT4 350/ZF 6 speed
2000 Bonneville SSEI Supercharged 3.8 Liter V6
1966 Chevelle 2 door sedan (Needs major repair )
77gmcjoe is offline   Reply With Quote
Old 11-06-2004, 08:04 PM   #2
earl87gta
earl87gta's Avatar
Boot s to the top on mine I would think it doesnt matter but I dont know for sure most poeple I think put them on top so they can be sean on the front end. but with resavor shocks its esyer to moiunt them boot down so you res is closer to ware it will be mounted.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-06-2004, 09:43 PM   #3
1FaastC10
1FaastC10's Avatar
it does matter, boots up unless specified otherwise by the manufacturer. 99% of over the counter shocks will go shaft up.
1FaastC10 is offline   Reply With Quote
Old 11-06-2004, 10:45 PM   #4
77gmcjoe
77gmcjoe's Avatar
Thanks for the info, gentlemen!
Joe
Old 11-07-2004, 08:30 PM   #5
kwmech
Ditch the boots---they will destroy the shocks by trapping moisture and dirt
Old 11-08-2004, 02:53 AM   #6
BurnoutNova
BurnoutNova's Avatar
your joking, right?
what about all the crap they'll have on them without the boots
BurnoutNova is offline   Reply With Quote
Old 11-14-2004, 08:22 PM   #7
flatblackclassic
Their is a seal that is designed to withstand that, but if water gets trapped it can get past the seal and ruin the shock.
flatblackclassic is offline   Reply With Quote
Old 11-14-2004, 08:50 PM   #8
LONGHAIR
Most of the gas shocks on the market say that they can be mounted either way. Many of the off-road racers mount them shaft end down to take un-sprung weight off of the axle. When running multiple shocks per wheel it makes more of a difference.
Some of the mounting preference will depend upon your use; mud, sand, rocks.......
It is easier to keep the shafts clean(mud) if you leave the boots off, though they may protect against the effects of sand better if left on.... again it depends upon intended use...
The typical 4x4 truck shocks are not "tuned" to a jounce/rebound percentage like a sports car or drag racing shock where being upside-down would affect thier performance. Most 4x4 truck shocks are "velocity sensitive" to give an acceptable on road ride and still have the travel for off-roading.
LONGHAIR is offline   Reply With Quote
Old 11-28-2004, 07:17 PM   #9
4x4Poet
What brand and model shocks? Please ask a specific question. As worded, your question has a textbook size answer since there are so many shocks available when one considers high-end shocks. AFAIK. all twin tube shocks go shaft up, body down to keep the "reservior" oil from draining away from the valves.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
Old 11-28-2004, 07:20 PM   #10
77gmcjoe
77gmcjoe's Avatar
They're the ones that came with the lift kit. I think they're Pro Comp gas shocks.
Old 11-28-2004, 08:29 PM   #11
4x4Poet
Then they could be monotube. See a model desigation? (MX-6?) You could pull the part number off the shock body to verify if mono or twin tube. I still expect they go on shaft up, body down. Somewhat rare the other way.
Old 11-28-2004, 10:43 PM   #12
77gmcjoe
77gmcjoe's Avatar
Thanks buddy!
Old 11-29-2004, 10:03 AM   #13
toddol1971
Hey Joe, why dont ya just give Pro-Comp a call. I'm sure they'll tell in a matter of minutes. www.explorerprocomp.com 1800 776 0767
All my trucks are gone now. I'll gladly take a free one
toddol1971 is offline   Reply With Quote
Old 11-29-2004, 10:06 PM   #14
77gmcjoe
77gmcjoe's Avatar
Good idea. Why the heck didn't I think about that?
